Ianpl's avatar
Ianpl
6 months ago
Red Light Permanently On Hub 3
I have tried the recommendations of unplugging and leaving before restarting the hub several times and the pin reset but the red light is still on. The hub is warm but not hot to touch and in an open space. Is there anything else I can try? Thanks.
  • my previous box was like that for years when in modem only mode. I read somewhere, some versions of SH3 are like that. If it ain't broke, don't fix it.
    • Ianpl's avatar
      Ianpl
      In the last few days wifi connection and speeds have been erratic, I assume this is related to the red light/overheating fault?
      • Sabrina_B's avatar
        Sabrina_B
        Hi Ianpl 👋.
        Thanks for reaching out to us, sorry to hear of the issues that you are facing with the red light on your Hub. The red light can be a number of this, It can be fault related, or healthy and safety In terms of the Hub overheating, and can also be the LED has simply broke and Is Stuck on Red but the service remains the same. In these circumstances we do not leave it to chance and need to bring you in for a private message to get some details and arrange for this to be replaced.
        Please look out for the envelope on the top right of your web browser or if you are using a mobile device, it will be located under your profile icon.
        Thanks.
        Sabrina
