- AdduxiVery Insightful Person
If this is a Hub 3 and if the red LED persists after a pinhole reset, the Hub should be swapped out. This red LED is the overheat warning and should be working correctly. If you wait here a couple of days a VM Mod should pick this up and discuss directly with you.
Note this LED error will not have any impact on the performance of the Hub. That will be a different problem.
- Matthew_ML
Hey ElZilch0, thank you for reaching out and we are so sorry to hear about your red light issue.
Thank you for confirming the steps you've done.
Please do try these for us;
• Then use the power switch to turn the unit back on. The Hub should now operate normally.
We will send you a DM now.
- Matthew_ML
DM has been sent :)
Related Content
- 2 years ago
- 3 years ago
- 4 months ago
