LewisRutty's avatar
LewisRutty
Red light on Virgin Media Hub
Have a solid red light on my Hub 3, has been like that for a few weeks, have reset it and pinhole reset but to no avail.
On another thread, someone said it was a overheating warning and they got sent a replacement.
Can anyone help?
    If the red LED persists after a pinhole reset, the Hub should be swapped out. This red LED is the overheat warning and should be working correctly. If you wait here a couple of days a VM Mod should pick this up and discuss directly with you.
  • Hi LewisRutty,
    We're sorry to hear you're having an issue with your hub displaying a red light. We won't be able to fix this remotely so I would like to arrange for an engineer to come to take a look at this for you. They will check things over and replace the hub if needed.
    I just need to confirm the address to ensure we are booking the visit on the correct account. I have sent you a direct message to allow us to do this with you in a private space. Just click on the little ✉ at the top right-hand side of the page to access your inbox. 😊
