Donna23's avatar
Donna23
Red light on Virgin Media Hub
Hi, my VM hub is showing a red light. We have tried factory reset as other people have tried, and we still cannot get any signal from it. It has been running pretty slow but now getting nothing from it at all. Could someone PM me for some advice please. Thanks ☺️
    If the Hub 3 red LED persists after a pinhole reset, the Hub should be swapped out. This red LED is the overheat warning and should be working correctly. If you wait here a couple of days a VM Mod should pick this up and discuss directly with you.
  • Hi Donna23,
    We're sorry to hear you're having an issue with your hub. We'd love to take a look in to things but have been unable to locate you on our systems using your forum credentials. 🙁 We will need to confirm some information with you in order for us to proceed with checks.
    I have sent you a direct message to allow us to do this with you in a private space. If you are using a PC/Laptop then you can just click on the little ✉ at the top right-hand side of the page to access your inbox. If you are on a mobile/tablet device then instead click on the little circle icon in the top right then select 'Messages'. 😊
  • I have tried turning on and off, pinhole reset and it's not fixed the solid red light (overheating) issue.  VM please contact me and help resolve this issue.
  • I have red light on VM hub. Tried to contact Virgin for 7 days. Reset then nothing. Can someone from virgin sort this for me?
    • Lee_R's avatar
      Lee_R
      Hi Kathrynh1 thanks for posting and welcome to our community.
      Sorry to hear of any concerns the constant red light on your hub may be giving you. I'd like to help you resolve this. I'm going to send you a private message. Please keep an eye on your inbox in the top right of your screen.
      Lee_R
