Hi babaganoosh33,
Thank you for your post and welcome back to our community forums. We're here to help.
I'm sorry to hear that you had a constant solid red light on your Hub 3. If you haven't done so already, please follow each of the steps below.
• Then use the power switch to turn the unit back on. The Hub should now operate normally.
If the issue remains after following the above then please respond to the private message that I'll be sending to you shortly and we can proceed from there.
