Rachael8's avatar
Rachael8
I have a solid red light on my hub3
I have noticed today that my hub3 has a solid red light. It is usually white. I’ve read it could be overheating and to make sure the vents are clear but they are (it’s been in the same place since I had it). I’ve switched it off and back on again and no change. The WIFI appears to be working fine. Any advice?
  • Anonymous's avatar
    Anonymous
    Yes, firstly don't panic!
    Almost certainly you have an old Hub 3 where the LED lamp is aging and these things tend to look red when they start to fail. So, as long as you have felt it and it does’t seem too hot, then you are OK.
    But. the hub does need to be swopped out on the grounds that, if it were to overheat in the future, then how would you know!
    Give it a day or so and a member of the forum team (VM employees) will get to this thread, offer to contact you via personal message and arrange for a new hub to be sent.
    Anonymous
  • Lee_R's avatar
    Lee_R
    Hi Rachael8 thanks for posting and welcome to our community.
    Sorry to hear of any concerns the permanent red light on your hub may be causing. I'd like to help you resolve this issue. I'm going to send you a private message. Please keep an eye on your inbox in the top right of your screen.
    Lee_R
