BrandyFife
6 months agoTuning in
Red Hub Light
Like other Superhub users it looks like I have the dreaded constant red light on my hub. I have tried the on and off and the reset but to no avail. The Hub isnt that hot and the onboard diagnostics s...
- 6 months ago
The LED driver that operates the light does wear out over time. In order to get a white light, the Green part of the LED is overdriven & this eventually fails just leaving you with just Red.
As this is a safety issue in itself, the hub will need to be swapped out by a technician. I have escalated this thread & a Forum Team member will post here shortly, take your details via Private Message & get a technician visit booked for you.
