ochippendale's avatar
ochippendale
Re: Red light on Virgin Media Hub
Hello
I am facing the exact same issue. A solid red line on the hub despite resetting. Please can you help.
  • Daniel_Et's avatar
    Daniel_Et
    Hi ochippendale 👋 Thank you for your post and welcome to the Virgin Media Community 😀
    We're sorry to hear about the issue you're facing 😔
    In the first instance, please follow the below steps in the following order:
    • Turn the power switch off on the back of the Hub
    • Ensure the Hub is upright, in a well-ventilated location, and, if at all possible, out of direct sunlight
    • Use the power switch to turn the unit back on
    If after following the steps the router doesn't boot back up after a few minutes, or the red light returns when it does, it'll need replacing.
    Regards,
    Daniel
    • ochippendale's avatar
      ochippendale
      Thanks for the assistance.
      Unfortunately that has not solved the issue.
      Please can you advise as to how to I can get a replacement sent.
