Millsy87's avatar
Millsy87
Re: Red light on hub
  • My hub too has a solid red light even after having tried the pin hole reset. I still have access to the Internet but the hub does feel warm nearer the top side of the device, wven though it's placed in a well ventilated area of the room. The Internet has also become intermittent, whether as too this issue or another. Any help would be appreciated. Thanks
1 Reply
  • Zach_R's avatar
    Zach_R
    Hi Millsy87,
    I'm very sorry to hear you're getting a solid red light on the router. If you haven't done so already, please follow each of the steps listed below.
    • Then use the power switch to turn the unit back on. The Hub should now operate normally.
    If the issue remains despite following those steps then please respond to the private message I'll be sending your way shortly and we'll assist you further from there.
