Tezbedz's avatar
Tezbedz
Re: Ethernet issue: Powerline adapters not connected
I have had the same problem since Saturday, although with a Hub 5.0. I have had the hub connected through 2 TP Link Powerline adaptors for about 4 years with no problems.
I have 3 lights on each Powerline adaptor and PC shows a connection but no Internet. if I connect WIFI to my phone I get a signal.
I bought a long cable but that does not work.
My hub is restarting which turns telly on, twice last night once this afternoon. Going to contact Virgin tomorrow
  • legacy1's avatar
    Use hub in modem mode and get your own router with 1Gb ports
    Try a 60 second pinhole reset, do not reboot the Hub as it will reboot itself when needed. Remove any cables before the reset.
  • Daniel_Et's avatar
    Daniel_Et
    Hi Tezbedz, thank you for your post.
    We're sorry to hear about the problem you've been having 😔
    How have things been since you posted? Also, have you considered/tried following the advice provided by legacy1, Adduxi and Roger_Gooner?
    Regards,
    Daniel
    • Tezbedz's avatar
      Tezbedz
      Thanks very much for your help after checking hub, powerline adaptors, cable. I fitted a new ethernet adaptor to PC. Bingo! That was the problem. 900Mbs to Shed.  Flight Simulator is up and running again
      I wanted to check everything my end before complaining about hub
        For your information, it has also been reported here that any NIC with the Ethernet Energy Saving feature can cause the Hub 5 ports to disconnect.  The solution is to disable the energy saving on the NIC.
