Kaleem71's avatar
Kaleem71
11 months ago
Random wifi drop out on hub 5
Hi, i have been experiencing random wifi drop outs of late. I have the hub 5 and from what i read and having spoken to customer service it has a problem of wifi drop out. If i change to a mesh system will that solve the problem and which one would be best to get if that is the case?
    If this is only a recent Wi-Fi problem, it could easily be signal to the house issue or a local fault.
  • legacy1's avatar
    It would be best to get a router as your main connection point and put hub in modem mode like this
    https://www.amazon.co.uk/ASUS-RT-AX57-Extendable-Subscription-free-Compatible/dp/B0BZJFQ4ZC
  • Tudor's avatar
    You do not say if cabled Ethernet connections are also affected, if they are it’s probably a circuit problem.
  • Daniel_Et's avatar
    Daniel_Et
    Hi Kaleem71, thank you for your post.
    We're sorry to hear about the problem you've been having 😔
    In order to discuss the matter with you further, we'll send you a private message on here. Look out for the envelope in the top right-hand corner.
    Thank you for your support Client62, legacy1 and Tudor 👍
    Regards,
    Daniel
