Callinder
11 months agoUp to speed
Pod use when moved to differnt home and Hub
I have two accounts with VM and used a Pod at one but decided to use an Access point instead. That property had a Hub 4 and 600 mbps broadband. Now I have the Pod but don't use it.
On my other account I have a Hub 5 and 1Gig broadband and use a Pod to extend the WiFi using an ethernet backhaul. Is there any chance of using the Pod from the home with a Hub 4 to my flat that uses a Hub 5?
Hi Callinder
You'd not be able to do so as the Pod is registered to one account only and thus paired. It cannot be moved over in this scenario.
Best wishes.
