Tomw22's avatar
Tomw22
Permanent red light on Hub 3
lm another one with a permanent red light on my hub. Had intermittent problems for at least a year and tried all the resets and powering down etc. Been trying to get through to VM but end up in a loop. Sometimes when I do a check it says there is an issue and to check later’ when I check again it says it it ok.
What do I do next ?
Regards,
Boyd
1 Reply
  • Hi Tomw22 / Boyd.
    Thanks for posting and welcome to the community. Thanks for letting us know about the Red light and what you've done yourself.
    You'll need an engineer visit so I'll pop you a PM now to assist.
