DunPog's avatar
DunPog
Packet loss
Hello,
I've been having packet loss issues for a while now and I have tried contacting Virgin Media via Whatsapp for support, but all that was able to be done was factory resetting the router, which did nothing.
I have used multiple programs to try and observe the packet loss and try to figure out whats causing it, and most of the time it seems to be related to ip addresses that end with "network.virginmedia.net". This was with programs such as PingPlotter and WinMTR.
I am using a wired connection to the router, and I've tested packet loss on other devices running on WiFi, they are very similar which is unusual considering wired should be better.
When running the service status checker that Virgin Media has it always prompts me saying that there is a problem, except there doesn't seem to really be a fix for it, since it always resorts to either a factory reset or a reboot, either of which do nothing.
Would appreciate any help or advice.
Thank you.
  • You need an engineer or this is a street cabinet fault that is yet to be reported.
    Almost all the Downstream channels are below acceptable levels of power.
    Only one 3.0 DOCSIS channel is connected - we normally see between four and six upstream channels.
    VM Customer Support are on 150 or 0345 454 1111 from a non-VM phone.
    • DunPog's avatar
      DunPog
      Thank you Client62, I'm not sure how I would go about getting an engineer to perform a check. If there is a number I could call or any other method would be appreciated.
      • Tom_W1's avatar
        Tom_W1
        Hi DunPog thanks for your post here in the Community although we're sorry to hear of your concerns raised.
        We can see since you've contacted us on here, you've received help via other means which is great news.
        If you still need support though please don't hesitate to reach out.
        Many thanks
  • Here is the full screenshot of RealSpeed showing the bottom part.
    3.0 Downstream channels
    1306000000-10.338QAM 25622
    2138000000-5.540QAM 2561
    3146000000-640QAM 2562
    4154000000-5.640QAM 2563
    5162000000-5.238QAM 2564
    6170000000-5.441QAM 2565
    7178000000-641QAM 2566
    8186000000-7.140QAM 2567
    9194000000-6.540QAM 2568
    10202000000-5.941QAM 2569
    11210000000-6.840QAM 25610
    12218000000-7.50QAM 25611
    13226000000-7.732QAM 25612
    14234000000-7.140QAM 25613
    15242000000-7.140QAM 25614
    16250000000-7.340QAM 25615
    17258000000-7.140QAM 25616
    18266000000-7.340QAM 25617
    19274000000-7.740QAM 25618
    20282000000-7.640QAM 25619
    21290000000-8.340QAM 25620
    22298000000-9.639QAM 25621
    23314000000-10.338QAM 25623
    24322000000-10.538QAM 25624
    25330000000-1138QAM 25625
    26338000000-11.138QAM 25626
    27346000000-10.638QAM 25627
    28354000000-10.439QAM 25628
    29362000000-10.239QAM 25629
    30370000000-1138QAM 25630
    31378000000-11.138QAM 25631
    1Locked38413456271
    2Locked4061256985737
    3Locked4091489903
    4Locked407785499
    5Locked384981137
    6Locked413070160
    7Locked415983277
    8Locked407437168
    9Locked404421199
    10Locked413869221
    11Locked405478246
    12Locked000
    13Locked3213355148137
    14Locked40313556
    15Locked40205165
    16Locked4048398103
    17Locked40620988
    18Locked403038179
    19Locked4025152673
    20Locked40132024470
    21Locked4099581866
    22Locked39108987855
    23Locked38748062673
    24Locked38114263039
    25Locked38443404938
    26Locked383750837166
    27Locked384556835
    28Locked39132947612
    29Locked39898241428
    30Locked3852648562
    31Locked38646064105
    3.1 Downstream channels
    33944K1840QAM 40961108
    33Locked27-19.474602976741477180
    Here is my Downstream Status
    3.0 Upstream channels
    03010000055.55120QAM 644
    0ATDMA0000
    3.1 Upstream channels
    1010.453.02KQAM 256
    10OFDMA2087400000000
    And here is my Upstream status.
    Finally, my broadband quality monitor which doesn't actually leak info like the one I blindly posted before.
    Thank you.
    If there a fault in your street ? Call 0800 561 0061 to find out.
    Seeing only 36.4 Mb/s Downstream to the VM Hub should be the start of your focus.
    The bottom of the Realspeed test is cropped off,
    so we can not tell if 19.7Mb/s Hub Upstream is OK or is this low too ?
    Check the Downstream / Upstream status tabs of the VM Hub for signal level or error issues.
    • DunPog's avatar
      DunPog
      Just called the number provided as well and apparently there are no faults in my area.
  • Thought I should also provide this, despite only starting it recently since I just found out about it, it also shows pretty clearly that there is an issue.
