Nigel1990's avatar
Nigel1990
Order wifi pod for spotty service in townhouse
We live in a 3 storey town house, On the 3rd floor our wifi reception is really spotty and sometimes will cut out while other times it runs full speed.
The app is refusing to let me order my free pod(s) by not even giving me the option for it eventhough we are on a volt 350 pack.
Is there any other way of ordering the pod(s) that doesn't involve the phone.
Thanks in advance
  • unapologetic bump to get a mods attention to order these pods as I refuse to sit there waiting on the phone to not be helped.
    This is the point at which you have a choice . . .
    1) Order online a decent Wi-Fi Mesh for the whole house and you can be using it tomorrow.
    2) Or waste hours on the phone to VM over the weeks / months ahead as VM try to not issue you 1 Pod at a time.
    Your call.
    • Nigel1990's avatar
      Nigel1990
      Yeah I was afraid of that, Claiming to give out free pods with a bundle and then having to jump through a million hoops to actually get one sent out.
      • Kath_P's avatar
        Kath_P
        Hi Nigel1990,
        We're sorry to hear that you're having issues with your WiFi connection. As part of Volt, we do include WiFi Max and where diagnostics determine that a pod can help, we do look to send one. Usually, the checks are performed within the Connect App and this will check all aspects of the WiFi network and allow you to run scans on each room. Where a WiFi pod can help, it would suggest this and allow you to order direct form the app.
        As you're not getting this option, we can check things from here and get the first pod sent for you. In order to do that I will need to confirm some information with you to pass security. I have sent you a direct message to allow us to do this with you in a private space. If you are using a PC/Laptop then you can just click on the little ✉ at the top right-hand side of the page to access your inbox. If you are on a mobile/tablet device then instead click on the little circle icon in the top right then select 'Messages'. 😊
