garypjackson's avatar
garypjackson
Dialled in
9 months ago
One of two ethernet PCs not showing as a connected device
Seems to be working OK but seems strange that it doesn't appear as a connected device.
I have the hub 3.0
    Are the two ethernet cables from the PC's directly connected to two separate ports on the the Hub 3?
    The Hub's Connected devices list only reports devices with a DHCP IP allocated by the VM Hub.
    Any device with a Static IP is not shown.
    Devices connected to the VM Hub via a 2nd Router or to a Wi-Fi Repeater with a DHCP server enabled will also not be shown.
