PatrickD06's avatar
PatrickD06
No RF Signal Detected - afternoon and evening
So... for the past three days the internet connection fails with either an RF signal or internet registration failure.
It fine in the morning but fails in the afternoon and remains with an error all evening. I noticed that the TV signal is also disrupted with jagged artifacts and picture degradation. Both issues are fine the next morning.
Anyone any clues? (TBH, am thinking of just switching to a 5g mobile broadband service - anyone know if you can get TV via a 5g service privider?)
  • nodrogd's avatar
    nodrogd
    Check the service status for your area via 0800 561 0061. This is either an SNR fault caused by VM street equipment or noise ingress. Or it is an issue with the cabling & connectors at your property causing either a weak signal or an RF ingress issue. If there are no issues on service status give the faults department a ring & get it investigated, as VM do not monitor individual customer connections.
    There are no TV services on 5G mobile. All they do is push data at you. What you do with it (Streaming platforms etc) is up to you.
    • PatrickD06's avatar
      PatrickD06
      Thanks - the weird thing is that it only happens from the afternoon onwards. Just started three days ago. Spoke to Virgin this morning (when it was working) and they couldn;t find any issues. Their sugestion was to swap out the router if it reoccurs. Very vague.
      • Ashleigh_C's avatar
        Ashleigh_C
        Hi there PatrickD06
        I am so sorry to hear that you have been experiencing this issue and a big thank you to our community members for their help and advise so far.
        Can I ask how things have been looking since your last post?
    Check for a service fault in your street via 0800 561 0061 - it is an automated service.
    Customer Support are on 150 or 0345 454 1111 from a non-VM phone to report the fault.
