timfurnell's avatar
timfurnell
21 days ago
New Hub installation
New Hub set up today BUT all wi-fi networks refer to the OLD Network Name and Password. Weirdly despite removal of old hub it seems to be working.  Have I done something wrong?  How do I confirm that I am connected to the new Network Name ?
  • jpeg1's avatar
    jpeg1
    The easiest thing to do with a new router is to go into the settings on 192.168.0.1, with a wired ethernet connection. Set the new Hub's SSID and password to the same as the old Hub. All your devices should then connect straight away.
    Do you use the VM Connect app?  This can set the "new" Hub to the same settings as the "old" Hub.
