- TudorVery Insightful Person
Check with Area faults on 0800 561 0061 If you have a VM landline 150 this goes down to post code level. You could also try the web page status, but this is not recommended as it only covers issues that affect a very large number of customers.
VM will not dispatch any technicians while an area fault exists.
If no area faults found:
- Matthew_ML
Hey Pmk81, thank you for reaching out and I am sorry to hear this.
I am going to send you a DM, but please try these steps for us in the meanwhile;
• Then use the power switch to turn the unit back on. The Hub should now operate normally. Cheers
Related Content
- 2 years ago
- 4 months ago
- 9 months ago
- 5 months ago
