Vim1965's avatar
Vim1965
Mesh or Wifi Pods
The story so far
Had a Hub 3 using with a Tenda MW6.
Hub went down and after spending best part of Sunday, VM swapped out on Monday with a Hub 5. Could not fault the speed of arranging the engineer and the swap.
At the moment have setup the mesh BUT previously VM have sent me 3 WiFi pods. These were meant to be used Hub 3.
So my question is should I stick with the Tenda mesh or switch over to the pods?
Yours comments please
  • You could use both. Put the Tenda into bridge mode and you can then use it with the hub in router mode. With networking it’s always best to experiment.
  • Tudor's avatar
    • Vim1965's avatar
      Vim1965
      Thank you for replying
      I think I will try out the pods first.
      I hope this works, I need to take the Hub out of modem mode, change the Hub 5 network/password to my mesh network/password, setup one pod at a time and put it into location. Repeat for all three pods and see what happens.
      Timing this is going to be crucial as probably need to be done on a Saturday when the WFH gang are not working.
      Will report back when done.
