Chris_Myers's avatar
Chris_Myers
Superfast
3 years ago
low device signal strength on Hub 5
So, having rebooted my Hub 5 following a broadband upload speed boost, I ran a network check on the hub and was told there were WiFi Issues.  The upshot is that two devices were flagged as "The device has low signal strength, please move it closer to Hub 5" followed by "Please place your Wi-Fi device near the Hub 5".
Firstly the messages do not identify which devices these messages refer to, but also the whole purpose of Wi-Fi is NOT to have the device immediately adjacent to the hub. I already need two Wi-Fi extenders to get the signal from my router (upstairs study) to devices (including TIVO box) in my downstairs lounge. Questions:
1. What Device is having a problem (is there a simple way to identify this)?
2. Are Virgin Media honestly saying they cannot provide a stable Wi-Fi Service unless I put all my devices in the same room as the router?
    Beth_G is advising of another problem with your internet connection that is unrelated to the Wi-Fi signal.
    It should be possible to see on the Upstream / Downstream tabs of the VM Hub the concern with signal levels to the VM Hub that an engineer is required correct.
  • legacy1's avatar
    I would bet downstream power levels are not to blame
    The hub wifi is just bad
    What is on the Upstream / Downstream status tabs that caught the eyes of Beth_G ?
  • Downstream Power Range 6.5 to 8.9 Across channels 1-31
    Upstream Power Range 42 to 42.8 Across channels 0-4
    • Tom_W1's avatar
      Tom_W1
      Hi Chris_Myers thanks for your reply.
      I can see your comments but also noticed you are now in a PM conversation with Beth directly.
      If you've got any further concerns with this matter, please continue to talk to her via that avenue.
      Many thanks
    Is the issue in the stats for the 3.1 Channel data ?
    • Chris_Myers's avatar
      Chris_Myers
      Superfast
      3.1 Upstream channels
      ChannelChannel Width (MHz)Power (dBmV)FFT TypeModulation
      1210.437.52KQAM 256
  • Suggestion was to send out an engineer - suprisingly "miraculously" resolved without an engineer visit
