ChilliHead's avatar
ChilliHead
Losing connection on a regular basis
I'm a keen gamer and keep losing my connection for like 25 seconds which then kicks me out of my game, this has been going on for a 3 weeks now.
26-07-2024 16:50:52noticeGUI Login Status - Login Success from LAN interface
26-07-2024 08:57:31warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
26-07-2024 08:57:31noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
26-07-2024 07:48:03warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
26-07-2024 07:48:03noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
24-07-2024 12:44:29noticeGUI Login Status - Login Success from LAN interface
24-07-2024 09:24:48warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
24-07-2024 09:24:48noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
24-07-2024 09:24:43noticeREGISTRATION COMPLETE - Waiting for Operational status
24-07-2024 09:24:36criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
24-07-2024 09:24:35warningDynamic Range Window violation
24-07-2024 09:24:35warningRNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
24-07-2024 09:24:35warningREG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
24-07-2024 09:24:35warningRNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
24-07-2024 09:24:29noticeDS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
24-07-2024 09:24:28noticeTLV-11 - unrecognized OID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
24-07-2024 09:24:17warningDHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
24-07-2024 09:24:15noticeHonoring MDD; IP provisioning mode = IPv4
24-07-2024 09:24:02warningToD request sent - No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
24-07-2024 09:24:01criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
24-07-2024 09:21:38noticeCM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
24-07-2024 09:21:28noticeCM-STATUS message sent. Event Type Code: 4; Chan ID: 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QO
24-07-2024 09:21:28noticeCM-STATUS message sent. Event Type Code: 22; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
24-07-2024 09:21:28noticeCM-STATUS message sent. Event Type Code: 23; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
24-07-2024 09:21:28noticeCM-STATUS message sent. Event Type Code: 5; Chan ID: 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.
24-07-2024 09:21:07warningTCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
24-07-2024 09:21:01criticalNo Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
24-07-2024 09:20:51warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
24-07-2024 09:20:51criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
  • nodrogd's avatar
    nodrogd
    If you post the downstream/upstream power stats it will show up if there is an issue with your individual connection to VMs network. VM does not monitor beyond cabinet level, so cannot detect individual line faults.
  • ChilliHead's avatar
    ChilliHead
    Still losing connection:
    27-07-2024 20:06:16noticeGUI Login Status - Login Success from LAN interface
    27-07-2024 19:41:54warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    27-07-2024 19:41:54noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    27-07-2024 19:31:19noticeGUI Login Status - Login Success from LAN interface
    27-07-2024 18:50:42noticeGUI Login Status - Login Success from LAN interface
    27-07-2024 18:39:47noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    27-07-2024 18:39:47warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    27-07-2024 18:02:32noticeGUI Login Status - Login Success from LAN interface
    27-07-2024 17:49:50warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    27-07-2024 17:49:50noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    27-07-2024 17:49:46noticeREGISTRATION COMPLETE - Waiting for Operational status
    27-07-2024 17:49:41warningREG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    27-07-2024 17:49:41warningDynamic Range Window violation
    27-07-2024 17:49:41warningRNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    27-07-2024 17:49:41warningRNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    27-07-2024 17:49:36noticeDS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    27-07-2024 17:49:32noticeTLV-11 - unrecognized OID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    27-07-2024 17:49:30warningDHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    27-07-2024 17:49:28noticeHonoring MDD; IP provisioning mode = IPv4
    27-07-2024 17:49:16criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    27-07-2024 17:49:15criticalCable Modem Reboot because of - HW or Power-On Reset
    24-07-2024 09:20:29criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    24-07-2024 09:20:28criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    24-07-2024 09:20:08criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    24-07-2024 09:20:08criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    24-07-2024 09:20:07criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    24-07-2024 09:20:07criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    24-07-2024 09:18:42criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    24-07-2024 09:18:38criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    3.0 Upstream channels
    049600000485120QAM 641
    14310000048.35120QAM 642
    23660000048.55120QAM 643
    33010000048.35120QAM 644
    42360000047.55120QAM 645
    0ATDMA0000
    3ATDMA0000
    4ATDMA0000
    3.1 Upstream channels
    61042.22KQAM 256
    6OFDMA2007400000000
    3.0 Downstream channels
    11390000001.240QAM 2561
    21470000001.441QAM 2562
    31550000001.541QAM 2563
    41630000001.741QAM 2564
    51710000001.941QAM 2565
    61790000001.941QAM 2566
    71870000002.141QAM 2567
    81950000002.641QAM 2568
    92030000002.641QAM 2569
    102110000002.841QAM 25610
    112190000002.541QAM 25611
    122270000001.640QAM 25612
    132350000001.141QAM 25613
    142430000001.741QAM 25614
    152510000001.841QAM 25615
    162590000002.241QAM 25616
    172670000002.541QAM 25617
    18275000000341QAM 25618
    192830000003.141QAM 25619
    202910000003.241QAM 25620
    212990000003.341QAM 25621
    223070000003.641QAM 25622
    233150000003.841QAM 25623
    243230000004.341QAM 25624
    253310000004.341QAM 25625
    263390000003.541QAM 25626
    273470000003.241QAM 25627
    283550000003.141QAM 25628
    29363000000341QAM 25629
    303710000003.241QAM 25630
    313790000003.341QAM 25631
    323870000003.241QAM 25632
    1Locked4026162820
    2Locked41222014256
    3Locked4135893167
    4Locked4196902509
    5Locked4117035344536
    6Locked4111932050772
    7Locked419273719729
    8Locked4120
    9Locked41510
    10Locked4120
    11Locked4110
    12Locked4010
    13Locked4120
    14Locked4110
    15Locked4110
    16Locked4110
    17Locked4110
    18Locked4110
    19Locked4120
    20Locked4140
    21Locked4170
    22Locked4110
    23Locked4100
    24Locked4100
    25Locked4100
    26Locked4100
    27Locked4100
    28Locked4100
    29Locked4100
    30Locked4110
    31Locked4100
    32Locked4130
    3.1 Downstream channels
    159944K1840QAM 40961108
    159Locked38-6.4134780357
    0
    ChilliHead
    This was in my logs prior to my last disconnection:
    28-07-2024 19:20:11criticalNo Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    28-07-2024 19:20:01criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    28-07-2024 19:20:01criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    28-07-2024 19:19:20criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    • Martin_N's avatar
      Martin_N
      Hi ChiliHead,
      Thank you for your post. I'm sorry to hear about the issue you're having.
      I am happy to take a look into this for you. I wll private message you now to confirm your details.
      ^Martin
