zico_84's avatar
zico_84
Just joined
Lose Wifi when Connect Network Cable
Hi All,
I have a weird issue. I have setup an outside office room in a garage. When I connect the network cable to Virgin Media router all the WIFI connections disconnect. I unplug the network cable and WIFI is back. The cable goes from Virgin Media router to Network point in garage
I initially tried to connect a Wireless Access Point to other end to allow WIFI in Garage to connect mutiple devices.
Is is the cable, a setting on router.
Any help would be appreciated.
  • What's the device model number in the garage?
    It's possibly a router trying to assign IP addresses at the same time as the HUB.
  • Tudor's avatar
    My guess is a bad cable. Get it tested out. Testers are cheap on places like Amazon.
