talcyh's avatar
talcyh
Longer coax cable
I'm having to move my router so am after a longer coax cable.  Can VM supply these?
  • They will supply one up to 3m - after that you need a Tech visit who will custom make one of the desired length and then rebalance the power levels.  They usually charge £25 for that its a "no fault" callout.
    Dont be tempted to buy one from online - no matter what the sell blurb claims these will not be authorised for use on the VM network and will cause you and your neighbours issues with "noise".
    Another solution if you can leave it connected to the existing point -  would be to run some Cat6a ethernet cable from a Hub port to the distant location and connect devices up there through a wireless access point with 1GB ethernet ports.
  • jbrennand's avatar
  • nodrogd's avatar
    nodrogd
    The longest pre-made cable VM supply is 3 metres. Any longer requires a technician visit. This is for 2 reasons:
    1) VM uses specialised cable that is specifically designed for Cable Broadband & TV services. You cannot buy this anywhere else, & using non standard cabling can cause issues with the entire local network.
    2) Changing the cable lengths affects your signal levels, which if they become unbalanced can affect your service performance.
    A technician will make up the required cable on site, & adjust levels in the local cabinet to compensate for the changes. There is a standard cost of £25 for the service.
    • LeonX's avatar
      LeonX
      Hi @talcyh
      Sorry to piggyback on your thread. I am also looking for a longer coax cable - 3m will do. Please can any VM members PM me as well?
      Thanks.
      • Kath_P's avatar
        Kath_P
        Hi LeonX,
        This is something we can certainly arrange for you. I have sent you a direct message to allow us to get some details from you in a private space. If you are using a PC/Laptop then you can just click on the little ✉ at the top right-hand side of the page to access your inbox. If you are on a mobile/tablet device then instead click on the little circle icon in the top right then select 'Messages'. 😊
    • Kath_P's avatar
      Kath_P
      Hi talcyh,
      This is something we can certainly arrange for you. Can you let us know if the 3m cable will be long enough or whether it's an engineer visit you require?
  • I think I’ll need a longer coaxial cable also for similar reasons (moving the box elsewhere in the room).
    • Vikki_M's avatar
      Vikki_M
      Hi ScottNapster,
      I'll send you a private message now so we can discuss if a cable or engineer visit is needed.
      Please look out for the envelope in the top right of the page and pop back to me when you can.
    • Vikki_M's avatar
      Vikki_M
      Hi ScottNapster,
      Thank you for joining me in a private message.
      I'm happy we were able to reach a resolution together 😊
      If you have any further questions or concerns, please pop back to us here on the community forums and we'd be happy to help.
      Take care.
  • Hi,
    Can I please ask to be contacted regarding a longer cable too. 3m should be plenty, so no engineer is required.
    Thank you.
    Chris.
    • Kath_P's avatar
      Kath_P
      Hi Chris,
      I'm afraid we don't offer a 3M cable option. If you would like a 3M length of coaxial, this would need to be done via an engineer visit. For that, there would be a charge of £25.
      We can offer a 5M cable instead if that's any good? I have sent you a direct message to allow us to help further. If you are using a PC/Laptop then you can just click on the little ✉ at the top right-hand side of the page to access your inbox. If you are on a mobile/tablet device then instead click on the little circle icon in the top right then select 'Messages'. 😊
      • Anonymous's avatar
        Anonymous
        Hi Kath,
        Sorry to jump on this thread but I too need 3m coax cable for my VM Hub 5. The existing cable is the very short one I had when Cable Modem installed back in 2002! and used to sit on top of a PC.
        Also do you do a long phone extension cable too, please? When my phone was converted to digital the engineer didn't have a very long extension lead (I accept there is a limit on length due to signal loss etc) but the hub is very restricted due to that and the short coax cable.
        Hope you can help.  I await your  message to pass security. I won't try phoning before anyone suggests it 😉
        Many thanks for your time.
  • Hi,
    I am in need of a longer cable to connect from the wall to my hub 3? Hoping VM can help on here as I can’t find anywhere else to ask them.
    • Carley_S's avatar
      Carley_S
      Hi Stewart1623
      Do you know how long the cable you need is, depending on this could mean an engineer might be required. If we need to arrange an engineer, this would be a £25 call-out charge.
      Let us know if that would be okay.
      • Stewart1623's avatar
        Stewart1623
        Hi an extra 2m would be enough but if it’s longer that’s fine
    • FsD25's avatar
      FsD25
      Hello all,
      Just got a new Hub 5 and shall require a longer 3m cable. Hoping any VM folks on the board can assist me with this?
      Unfortunately the wait times for me are prohibitive during my working day!
      Cheers!
      • Carley_S's avatar
        Carley_S
        Hi FsD25
        I'm afraid we don't offer a 3M cable option. If you would like a 3M length of coaxial or if you need a longer indoor fibre cable, this would need to be done via an engineer visit. For that, there would be a charge of £25.
        If it is a coaxial cable that you need and not a fibre, then we can send a 5M cable if that works. However, this is not an option for fibre, so please let us know what you need for your setup, and we can support further.
    • Matthew_ML's avatar
      Matthew_ML
      Glad we've managed to order you a coax cable :)
