2 months agoVery Insightful Person
See Tudor's reply here as a starter/example..
MotoGPMaz
2 months agoTuning in
Thank you I bought a tp link lan box and updated lan cable and it worked. Appreciate the help, as the helpline didn’t gave a clue and quite frankly didn’t care. Cancelled the engineer. Quite proud of myself lol 😂
- newapollo2 months agoVery Insightful Person
Well done MotoGPMaz - I'm proud of you too.
Most posters on the forums are pretty good with their advice and there are some great tech guru's amongst them that are well versed in broadband problems and can also think outside of the box when needed.
If you do have any future issues please try the forums again as their advice is based on common problems that crop up in the forums.
- jbrennand2 months agoVery Insightful Person
Well done - I knew you would get a fix from someone - if not me 😎
Which TP-Link switch did you go far ?
Related Content
- 12 months ago
- 10 days ago
- 2 months ago
- 5 months ago
