Edytamiro201052's avatar
Edytamiro201052
Hub3 heats up and glows red
Hello
I've had Hub3 for over three years. I noticed it was glowing red and hot. There's often a big drop in data transfer. I have restarted many times using the button, and also disconnected it from the power supply. Nothig to help.
  • Tudor's avatar
    I’ll report it. Hub needs replacing
  • Hey Edytamiro201052, thank you for reaching out and I am sorry to hear this,
    I can see you are currently speaking to my colleague about this :)
    • Edytamiro201052's avatar
      Edytamiro201052
      Problem solved 😁👍🏻 The technician came last Friday and replaced the router.
