See Tudor's reply here as a starter/example..
- MotoGPMaz2 months agoTuning in
Will a higher cat Ethernet cable work to connect this t p link hub to my mode, then I can plug my heating system into the t p box?
- Robert_P2 months agoForum Team
Hello MotoGPMaz
Thanks for posting on the forums in regards to your hub and port issues, we appreciate you letting us know via the forums and welcome to the community.
From checking, we can see you have spoken to the team earlier today in regards to this. We trust they were able to help and offer a resolution to your query, if you do need further support please don't hesitate to reach out via the forums.
- Roger_Gooner2 months agoAlessandro Volta
If a new Ethernet cable doesn't work, try Client62's suggestion. Here's some low-cost switches for sale.
- carl_pearce2 months agoCommunity elder
Or purchase a £12 switch, which is plug and play.
Thank you I bought a tp link lan box and updated lan cable and it worked. Appreciate the help, as the helpline didn’t gave a clue and quite frankly didn’t care. Cancelled the engineer. Quite proud of myself lol 😂
- newapollo2 months agoVery Insightful Person
Well done MotoGPMaz - I'm proud of you too.
Most posters on the forums are pretty good with their advice and there are some great tech guru's amongst them that are well versed in broadband problems and can also think outside of the box when needed.
If you do have any future issues please try the forums again as their advice is based on common problems that crop up in the forums.
- jbrennand2 months agoVery Insightful Person
Well done - I knew you would get a fix from someone - if not me 😎
Which TP-Link switch did you go far ?
Related Content
- 12 months ago
- 10 days ago
- 2 months ago
- 5 months ago
