rickjhns's avatar
rickjhns
Is it possible to get Virgin WiFi pods with two ethernet sockets (I am on Volt 250 MB)?
I currently have two white WiFi pods.  I am still  struggling to get a reliable connection in one area of my house, I will request another pod, however, ideally I need a pod with two ethernet connections to supply reliable  internet to all the locations required. Does anyone know if it is possible to obtain a Virgin pod with two ethernet connection sockets?
Thanks.
  • Tudor's avatar
    I don’t use pods, have my own networking equipment. I doubt VM will change them, easiest way is to get a cheap 5 port Ethernet switch, about £15.
  • Joseph_B's avatar
    Joseph_B
    Hey rickjhns,
    Welcome to the Community Forums and thanks for the post.
    Sorry to hear you are still having issues with the connection in your house, we do have a Pod which has 2 Ethernet ports however we cannot guarantee which would be sent to you when you place your order, the system automatically assigns the one which is best suited to you services.
    Joe
