Jobie's avatar
Jobie
4 years ago
iPhone Wifi Internet problems with Hub 3
I have having daily intermittent problems with my two Apple iPhones with Wifi internet and my Virgin Media Hub 3, which is rendering my home Wifi to be pretty much useless.
The devices appear to connect to my Wifi but internet doesn’t work.  Sometimes on the iPhone WiFi settings it will say “No Internet Connection”, but not always.  However there will be no internet connection on the iPhones regardless.
I have a wired PC, two laptops and an Android device on WiFi, and also a smart TV on the WiFi and these ALL work perfectly – the problem only appears to be with the iPhones.  (I have an old iPad Air 2 and this works fine also).
My two devices are an iPhone 11 and an iPhone SE.  Both will connect to the internet on WiFi networks outside the house (eg. My workplace) and work without any problems whatsoever.
If I do a “forget this network” and rejoin, sometimes the device will reconnect, but to be honest it is driving us crazy as my home WiFi is effectively useless and is constantly eating up mobile data.
Doing a power off/on will sometimes resolve the problem but it is guaranteed the problem will occur again within a few hours, if not sooner.
I have tried – pin Resets, splitting the wifi Bandwidths to separate SSIDs. Static IPs, all to no avail.  I have had a Virgin engineer visit and of course his basic diagnostics found no problems.
I am at the end of my tether with this.  Is anybody able to advise?  Thanks in advance.
  • What has worked for me is changing the channels through the advanced settings at http://192.168.0.1 advanced settings
  • DCT1's avatar
    DCT1
    Just joined
    I gave up on VM ever solving this and went to Apple support.
    A quick chat with them (nice person "Dolby") and following request to reset all settings on apple device (Setting, general, transfer or reset iphone, and select reset (do NOT erase all content) - it asks for a 1hr delay due to security precautions... but thereafter my apple products (ipad 9 and iphone 13) have made and held wifi connection with VM hub 3)
    Its much easier to deal with a company like Apple than VM
    • carl_pearce's avatar
      carl_pearce
      Superstar
      Shock case of speaking to the manufacture of a device with issues for help rather than the ISP.
