Luggerbugs's avatar
Luggerbugs
Problems connecting to internet
Laptop having problems connecting to internet with hub 3, connects after numerous attempts but very erratic . Laptop connects to phone hotspot and network at another address, help please very frustrating.
  • These are our Hub 3 Wi-Fi settings ,  Smart Wi-Fi is disabled at the bottom of the page ...
  • just to add to above, I have phones iPads and numerous other devices connected, 19 in all, only having problems connecting to new laptop. I retired my old one which didn’t have any connection problems. Updated network adapter drivers, still having problems.
    Check the laptop works normally with the VM Hub when connected via network cable.
    Try with Smart Wi-Fi aka One Wi-Fi disabled in the VM Hub Menu.
    Try with the VM Hub Wi-Fi Security ( encryption method ) set to just : WPA2-PSK
    Share a screen shot of the connection errors.
    • Luggerbugs's avatar
      Luggerbugs
      Laptop works wired.
      don’t know how to disable smart WiFi? Can you explain how to do this please?
      already connect to WPA2-PSK only
      have seen your advise offered previously to others having similar problems, tried your suggestions but still having problems?
      Luggerbugs
      Sod’s Law, working fine right now but later, who knows.
      Luggerbugs
      Tried your suggestion, working so for, thanks for your input 🤞
