gingamonkey's avatar
gingamonkey
Intermittent internet speed issues
We've been having intermittent issues with our broadband for the past few weeks - We're on a 1GB package but it will drop to next to nothing randomly (Mbps will fall off a cliff on samknows.com) and I'm constantly having to power cycle the router to get it to kick start again.
Prior to this, we were having visual corruption on some tv channels. After a painfully long experience speaking to telephone support over numerous calls, they finally succumbed to booking an engineer. By the time the appointment came around, the issue appeared to resolve itself, so I cancelled the visit.
I'm thinking that there is more of an issue at play here, as we are now experiencing this prolonged internet issue. Working from home part time, remotely connecting to my office workstation is a nightmare, as every time it drops, I lose connection.
The forum admin team have been a HUGE help to me in the past, so I'm posting on here in the hope that they can please work their magic again, and help me avoid having to go through another telephone support nightmare!
Any help much appreciated!
  • Thank you - I'm seeing that the 3.1 downstream channel is way too low.
  • gingamonkey's avatar
    gingamonkey
    Hi, I think I’ve fixed it myself!
    I looked inside the new brown box on the outside of the house (it was loose to the wall due to being partially installed into old mortar - fixed now). Turns out the heads of the cables screwed into this box were all suffering from water ingress! Gave them a spot of electric contact cleaner and dried them off… not one drop out since I did it!
    I think rain water must have got in due to the dodgy install of the box. I know I probably shouldn’t have gone in there, but I’ve been at my wits end, paying for a service that I’m not receiving. All working now, saved an engineer visit, and now my box is securely fitted too!
    Result!👍🏼
      gingamonkey
      Actually no, spoke too soon. Been okay since around 4pm yesterday….. now it’s happening again! Looks like I still need that engineer visit!  😭
        gingamonkey
        Just managed to book a slot for Tuesday via the Virgin Media app! First time its actually worked for me 🎉
  • Sephiroth's avatar
    Sephiroth
    What you did in the brown box has likely been worth while. Micro-reflections occur when electrolytes form in components that have water ingress.
    If you'd care to provide your stats, we can see the difference your work has made (if any).
      gingamonkey
      Cancelled the appointment - Seems to be stable connection now with no dropouts...
    gingamonkey
    3.0 Downstream channels
    1331000000840QAM 25625
    213900000012.140QAM 2561
    31470000001240QAM 2562
    415500000011.740QAM 2563
    516300000011.640QAM 2564
    617100000011.440QAM 2565
    717900000011.640QAM 2566
    818700000011.240QAM 2567
    919500000011.340QAM 2568
    1020300000011.340QAM 2569
    1121100000011.340QAM 25610
    1221900000011.240QAM 25611
    1322700000010.740QAM 25612
    1423500000010.540QAM 25613
    152430000001040QAM 25614
    162510000009.440QAM 25615
    172590000009.340QAM 25616
    182670000008.940QAM 25617
    192750000009.140QAM 25618
    202830000008.640QAM 25619
    212910000008.840QAM 25620
    222990000007.839QAM 25621
    233070000008.140QAM 25622
    243150000007.839QAM 25623
    253230000007.839QAM 25624
    26339000000839QAM 25626
    273470000008.239QAM 25627
    283550000007.640QAM 25628
    293630000007.840QAM 25629
    303710000007.740QAM 25630
    313790000007.540QAM 25631
    323870000007.339QAM 25632
    1Locked401500
    2Locked4070
    3Locked40100
    4Locked4080
    5Locked4050
    6Locked4080
    7Locked4060
    8Locked4090
    9Locked4060
    10Locked4080
    11Locked4050
    12Locked4080
    13Locked4060
    14Locked4080
    15Locked4070
    16Locked4050
    17Locked4060
    18Locked4090
    19Locked40490
    20Locked40760
    21Locked401440
    22Locked392110
    23Locked402400
    24Locked391640
    25Locked392570
    26Locked392694
    27Locked3922692
    28Locked40176216
    29Locked40162242
    30Locked40126336
    31Locked40122331
    32Locked39130383
    3.1 Downstream channels
    159944K1840QAM 40961108
    159Locked37-1.213401779532949
    3.0 Upstream channels
    04960000038.55120QAM 641
    14310000038.35120QAM 642
    23660000037.55120QAM 643
    33010000037.55120QAM 644
    42360000037.55120QAM 645
    0ATDMA0040
    3ATDMA0000
    4ATDMA0000
    3.1 Upstream channels
    61032.72KQAM 256
    6OFDMA2007400000000
    Time
    Priority
    Description
    15-07-2024 20:58:07
    notice
    GUI Login Status - Login Success from LAN interface
    14-07-2024 08:28:25
    warning
    DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=##:##:##:##:##:##;CMTS-MAC=##:##:##:##:##:##;CM-QOS=1.1;CM-VER=3.1;
    14-07-2024 08:28:25
    notice
    US profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 11 13.;CM-MAC=##:##:##:##:##:##;CMTS-MAC=##:##:##:##:##:##;CM-QOS=1.1;CM-VER=3.1;
    14-07-2024 08:28:21
    notice
    REGISTRATION COMPLETE - Waiting for Operational status
    14-07-2024 08:28:16
    warning
    Dynamic Range Window violation
    14-07-2024 08:28:16
    warning
    14-07-2024 08:28:16
    warning
    RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=##:##:##:##:##:##;CMTS-MAC=##:##:##:##:##:##;CM-QOS=1.1;CM-VER=3.1;
    14-07-2024 08:28:16
    warning
    14-07-2024 08:28:15
    warning
    RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=##:##:##:##:##:##;CMTS-MAC=##:##:##:##:##:##;CM-QOS=1.1;CM-VER=3.1;
    14-07-2024 08:28:15
    warning
    14-07-2024 08:28:15
    warning
    REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=##:##:##:##:##:##;CMTS-MAC=##:##:##:##:##:##;CM-QOS=1.1;CM-VER=3.1;
    14-07-2024 08:28:10
    notice
    DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=##:##:##:##:##:##;CMTS-MAC=##:##:##:##:##:##;CM-QOS=1.1;CM-VER=3.1;
    14-07-2024 08:28:09
    notice
    TLV-11 - unrecognized OID;CM-MAC=##:##:##:##:##:##;CMTS-MAC=##:##:##:##:##:##;CM-QOS=1.1;CM-VER=3.1;
    14-07-2024 08:28:02
    warning
    DHCP WARNING - Non-critical field invalid in response ;CM-MAC=##:##:##:##:##:##;CMTS-MAC=##:##:##:##:##:##;CM-QOS=1.1;CM-VER=3.1;
    14-07-2024 08:28:00
    notice
    Honoring MDD; IP provisioning mode = IPv4
    14-07-2024 08:27:36
    critical
    No Ranging Response received - T3 time-out;CM-MAC=##:##:##:##:##:##;CMTS-MAC=##:##:##:##:##:##;CM-QOS=1.1;CM-VER=3.1;
    14-07-2024 08:27:30
    critical
    SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=##:##:##:##:##:##;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    14-07-2024 08:27:29
    critical
    Cable Modem Reboot because of - HW or Power-On Reset
    13-07-2024 15:42:05
    critical
    Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=##:##:##:##:##:##;CMTS-MAC=##:##:##:##:##:##;CM-QOS=1.1;CM-VER=3.1;
    13-07-2024 15:36:40
    critical
    13-07-2024 15:36:02
    critical
    13-07-2024 15:35:49
    critical
    13-07-2024 15:35:49
    critical
    SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=##:##:##:##:##:##;CMTS-MAC=##:##:##:##:##:##;CM-QOS=1.1;CM-VER=3.1;
    13-07-2024 15:24:48
    critical
    13-07-2024 15:24:43
    critical
    13-07-2024 15:24:35
    critical
    SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=##:##:##:##:##:##;CMTS-MAC=##:##:##:##:##:##;CM-QOS=1.1;CM-VER=3.1;
    13-07-2024 15:24:34
    critical
    13-07-2024 15:24:17
    critical
    13-07-2024 15:24:14
    critical
    13-07-2024 15:23:55
    critical
    13-07-2024 15:23:54
    critical
    13-07-2024 15:23:15
    critical
    13-07-2024 15:23:14
    critical
    Sephiroth
    The stats you posted today and 13-July have a marked difference from the ones you posted in May.  Your downstream channels are at the same frequency but the power levels have risen - as if attenuation has been removed.  Did you remove any attenuators/splitters (the latter being more likely) or is it down to a dry connection which is an equal possibility?
      gingamonkey
      Nope, nothing has changed inside the house at all since the rewire from the pavement outside. Only thing I've done is dry the connections in the box outside the house.
      Don't want to tempt fate, but all still working as expected.  Thanks!
  • Issue wasn't noise or micro reflections. If you're curious look at the phenomenon 'suck-out'.
