farske's avatar
farske
9 months ago
Intermittent Internet, droppouts, signal strength issues
Hiya,
That last 10 days I've had internet issues and dropouts. Streaming TV/Film pauses, games disconnect, discord lags and drops, websites delay.
I am ethernet checking.
Modem mode.
Wired household.
Checking the router section I can see these types of issues:
25-05-2024 22:19:31noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
25-05-2024 22:01:01warningRNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
25-05-2024 21:49:43noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
24-05-2024 20:17:25 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Currently the modem has a 10db filter on it.
Is this something you can do your end?
Can you advise or arrange an engineer to resolve, thank you
  • farske's avatar
    farske
    31-05-2024 21:08:20warningRNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    31-05-2024 21:08:20warningDynamic Range Window violation
    31-05-2024 13:23:55noticeCM-STATUS message sent. Event Type Code: 24; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    31-05-2024 13:21:40warningRNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    31-05-2024 13:21:37noticeCM-STATUS message sent. Event Type Code: 16; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    31-05-2024 13:19:18warningRNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    31-05-2024 13:19:16noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    31-05-2024 13:14:49warningRNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    31-05-2024 13:14:49warningDynamic Range Window violation
    31-05-2024 13:14:47warningRNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    31-05-2024 13:14:47warningDynamic Range Window violation
    31-05-2024 13:14:13noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    31-05-2024 12:40:54warningRNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    31-05-2024 12:18:55noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    31-05-2024 12:07:04noticeCM-STATUS message sent. Event Type Code: 24; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    31-05-2024 12:05:54warningRNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    31-05-2024 12:05:15noticeCM-STATUS message sent. Event Type Code: 24; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    31-05-2024 12:03:52warningRNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    31-05-2024 12:03:35noticeCM-STATUS message sent. Event Type Code: 16; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    31-05-2024 12:03:33noticeCM-STATUS message sent. Event Type Code: 5; Chan ID: 14 26; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    31-05-2024 12:03:11warningRNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
  • farske's avatar
    farske
    So judging from what others have said, and how the errors have appeared a tech visit is required.
    • David_Bn's avatar
      David_Bn
      Thanks for reaching out to us farske, and welcome back to our Community Forums!
      Sorry to hear of the issues you've been experiencing with our services.
      Check out the envelope in the top right hand corner and we can arrange for the aforementioned engineer to be booked in for you
      David_Bn
  • Anonymous's avatar
    Anonymous
    You just need to look at the change in upstream power to know that something is wrong (~11 dB difference in power between the channels in the last post). That is why you get all those DRW/dynamic range window messages.
  • farske's avatar
    farske
    Last time I had an issue a few years ago VM supported me via this forum and arranged a visit. Hopefully they are still active here?
  • farske's avatar
    farske
    Its been a few months.
    I'm back with some updates.
    In the last week I've had some constant jitters, and small disconnections which drop me from VOIP and work in the day, and games and matches in the evenings.
    So, yeah I still have issues.
    Can peeps have a quick look at my logs and see if the efforts so far are positive?
    3.0 Downstream channels
    13310000004.542QAM 25625
    21390000003.441QAM 2561
    31470000003.341QAM 2562
    41550000003.341QAM 2563
    51630000003.642QAM 2564
    61710000003.842QAM 2565
    7179000000442QAM 2566
    8187000000442QAM 2567
    91950000004.142QAM 2568
    102030000004.142QAM 2569
    112110000004.342QAM 25610
    122190000004.342QAM 25611
    132270000004.142QAM 25612
    142350000003.942QAM 25613
    152430000003.642QAM 25614
    162510000003.642QAM 25615
    172590000003.842QAM 25616
    18267000000442QAM 25617
    19275000000442QAM 25618
    20283000000442QAM 25619
    212910000004.242QAM 25620
    222990000004.442QAM 25621
    233070000004.742QAM 25622
    243150000004.742QAM 25623
    253230000004.642QAM 25624
    263390000004.842QAM 25626
    27347000000542QAM 25627
    283550000004.942QAM 25628
    293630000004.942QAM 25629
    303710000004.742QAM 25630
    313790000004.942QAM 25631
    1Locked42753
    2Locked41138
    3Locked4177
    4Locked41108
    5Locked4229
    6Locked42118
    7Locked4268
    8Locked4248
    9Locked4258
    10Locked42137
    11Locked4268
    12Locked4248
    13Locked4267
    14Locked4228
    15Locked4278
    16Locked4258
    17Locked4258
    18Locked4286
    19Locked42136
    20Locked4257
    21Locked4267
    22Locked4286
    23Locked4297
    24Locked4277
    25Locked4247
    26Locked4277
    27Locked4267
    28Locked4278
    29Locked4257
    30Locked4247
    31Locked4267
    3.1 Downstream channels
    33944K1840QAM 40961108
    33Locked434.536089683162
    • Tom_W1's avatar
      Tom_W1
      Hi farske thanks for your post although we're sorry to hear of the concerns you've raised here.
      We've ran checks on our line and there aren't any issues currently, so have these issues now resolved themselves?
      Please keep us updated as all levels are within the appropriate specifications.
      Many thanks
  • farske's avatar
    farske
    3.0 Upstream channels
    04960000045.35120QAM 641
    143100000455120QAM 642
    23660000044.85120QAM 643
    33010000044.85120QAM 644
    42360000044.85120QAM 645
    0ATDMA0010
    3ATDMA0011
    4ATDMA0000
    3.1 Upstream channels
    610.440.22KQAM 256
    6OFDMA2087400000070
  • farske's avatar
    farske
    26-07-2024 17:37:02noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    26-07-2024 17:31:59noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    26-07-2024 17:31:23noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    26-07-2024 17:26:20noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    26-07-2024 17:24:20noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    26-07-2024 17:19:17noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    26-07-2024 17:17:57noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    26-07-2024 17:12:54noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    26-07-2024 14:56:29noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    26-07-2024 14:51:26noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    26-07-2024 12:38:22noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    26-07-2024 12:33:19noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    26-07-2024 10:29:31noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    26-07-2024 10:19:13noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    26-07-2024 00:25:27criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    24-07-2024 02:25:43noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    24-07-2024 01:30:01noticeREGISTRATION COMPLETE - Waiting for Operational status
    24-07-2024 01:29:57warningDynamic Range Window violation
    24-07-2024 01:29:57warningRNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    24-07-2024 01:29:56warningRNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    24-07-2024 01:29:55criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    24-07-2024 01:29:54noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    24-07-2024 01:29:49noticeDS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    24-07-2024 01:29:48noticeTLV-11 - unrecognized OID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    24-07-2024 01:29:41warningDHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    24-07-2024 01:29:39noticeHonoring MDD; IP provisioning mode = IPv4
    24-07-2024 01:27:00criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    24-07-2024 01:20:11criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    24-07-2024 01:20:07warningToD request sent - No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    24-07-2024 01:20:06criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    24-07-2024 01:20:06criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    24-07-2024 01:20:05criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
