willsetten
14 hours agoJoining in
Intermittent connection drops – upstream/downstream power issue
I've had this several times over the years, occasionally it gets worse for a day or two at a time then stabilises.
My hub is repeatedly rebooting due to upstream signal loss. The downstream power levels are hitting +8 dBmV, and my upstream power is around 40 dBmV with repeated T3 timeouts and sync timing failures. This indicates noise or a power-level issue on the coax line. I need a technician to check the external line, connectors, splitter, and cabinet.
