Jesicaalban4's avatar
Jesicaalban4
I need a help with Potential changes in port obstructing conduct?
Hello,
Whenever Now and again I play out an outer sweep on my organization so I can check that I haven't done anything moronic. For convenience I will more often than not utilize the "all assistance ports" choice.
Since I joined virgin media a couple of years prior, while running the test I generally saw "shut" (blue square) against a portion of the tricky ports, for example, netbios and some dangerous Microsoft administrations.
My supposition that was that they were impeded by the ISP as they should not be being reachable across the web. Be that as it may, I ran it earlier today to really look at something, and all ports are displayed as a green square, and that implies secrecy.
Any Help will be Appreciated
  • Hello
    Virgin Media's Blocked Internet Ports
    In order to protect our customers and our network, a number of ports on the Virgin Media network are blocked.
    Ports on the Internet are like virtual doors that data can pass through. All internet traffic passes through ports to get to and from systems and services across the Internet.
    When a certain port is known to be subject to security vulnerabilities, we sometimes block that port on our network.
    These ports are blocked at network-level. Traffic over these ports within your home network will continue to operate as normal, but will be inaccessible to devices outside your network.
    Blocked ports TCP & UDP ports 135, 137, 138, 139 – Used by the NetBIOS service
    NetBIOS services allow file sharing over a local network. When exposed to the Internet, it can be exploited to carry out malicious activities such as Distributed Denial of Service (DDoS) attacks or to gain unauthorised access to systems on a local network.
    TCP & UDP port 445 – Used by the SMB protocol
    Port 445 is vulnerable to a number of attacks which target vulnerabilities in systems running file-sharing services. This port is used by various malware strains to gain entry to a network, namely the WannaCry and Nimda malware variants.
    Regards Mike
  • DJ_Shadow1966's avatar
    DJ_Shadow1966
    Hello
    Regards Mike
    • Jesicaalban4's avatar
      Jesicaalban4
      DJ_Shadow1966 wrote:
      Hello
      These ports are blocked at network-level. Traffic over these ports within your home network will continue to operate as normal, but will be inaccessible to devices outside your network. BallSportsPro
      Regards Mike
      Thanks you for Answer I really Appreciated.
      • Lee_R's avatar
        Lee_R
        Hi Jesicaalban4
        As you've confirmed on another thread that you've resolved your issue, we will take steps to have them closed. Thanks for your updates and I hope your services run more smoothly for you moving forward.
        Lee
    With Hub 3 in Router mode, when the Firewall is enabled the ports do not respond ( Stealth / Green ), with the Firewall disabled the ports respond as closed ( Closed / Blue ).
    • 用心棒's avatar
      用心棒
      Out of curiosity, where are you seeing these green, blue indicators?
  • 用心棒's avatar
    用心棒
    What is observed that indicates network traffic on those ports reaches the Hub?
