bazzauns51's avatar
bazzauns51
I have a red light permanently on my hub 3
I have a red light on my hub3 permanently I have tried everything  including a pin restart to no avail. Anyone help,?
  • Same here, no problem with broadband or wireless though. The hub is slightly warm to the touch at the top. Staff on 151 were not very helpful.
    • Vikki_M's avatar
      Vikki_M
      Hi leftwinger
      Thank you for your post and welcome back to our community.
      We're  sorry to hear you have a permanent red light on the hub 😞
      If you have tried the below already, we'll need to replace the hub for you.
      • Then use the power switch to turn the unit back on. The Hub should now operate normally.
      I will send you a private message now, please look out for the envelope in the top right of the page and pop back to me when you can.
  • Vikki_M's avatar
    Vikki_M
    Hi bazzauns51
