Blackfox's avatar
Blackfox
3 days ago
Hub5 keeps disconnecting
Hi over the past few months the internet keeps randomly dropping iv had an engineer over to fix it but what ever they did it didnt work could any one have a look thanks
3.0 Downstream channels
Channel    Frequency (Hz)    Power (dBmV)    SNR (dB)    Modulation    Channel ID
1    179000000    6.4    42    QAM 256    6
2    139000000    7.4    42    QAM 256    1
3    147000000    6.9    42    QAM 256    2
4    155000000    7    42    QAM 256    3
5    163000000    6.8    42    QAM 256    4
6    171000000    6.6    42    QAM 256    5
7    187000000    6.5    42    QAM 256    7
8    195000000    6.6    42    QAM 256    8
9    203000000    6.4    42    QAM 256    9
10    211000000    6.5    42    QAM 256    10
11    219000000    6.4    41    QAM 256    11
12    227000000    6.2    41    QAM 256    12
13    235000000    6.2    41    QAM 256    13
14    243000000    6.1    41    QAM 256    14
15    251000000    6.1    40    QAM 256    15
16    259000000    6.2    40    QAM 256    16
17    267000000    6.2    40    QAM 256    17
18    275000000    6.3    40    QAM 256    18
19    283000000    6.2    41    QAM 256    19
20    291000000    6.1    41    QAM 256    20
21    299000000    6.1    41    QAM 256    21
22    307000000    6    41    QAM 256    22
23    315000000    6.1    41    QAM 256    23
24    323000000    5.9    41    QAM 256    24
25    331000000    5.9    41    QAM 256    25
26    339000000    5.8    41    QAM 256    26
27    347000000    5.8    42    QAM 256    27
28    355000000    5.7    42    QAM 256    28
29    363000000    5.6    42    QAM 256    29
30    371000000    5.6    42    QAM 256    30
31    379000000    5.6    42    QAM 256    31
Channel    Locked Status    RxMER (dB)    Pre RS Errors    Post RS Errors
1    Locked    42    10    64
2    Locked    42    9    93
3    Locked    42    11    103
4    Locked    42    10    106
5    Locked    42    14    156
6    Locked    42    10    72
7    Locked    42    11    63
8    Locked    42    11    105
9    Locked    42    10    94
10    Locked    42    16    153
11    Locked    41    9    56
12    Locked    41    11    112
13    Locked    41    15    144
14    Locked    41    7    71
15    Locked    40    17    109
16    Locked    40    7    55
17    Locked    40    9    98
18    Locked    40    11    105
19    Locked    41    4    31
20    Locked    41    11    110
21    Locked    41    7    83
22    Locked    41    12    155
23    Locked    41    4    32
24    Locked    41    7    72
25    Locked    41    10    52
26    Locked    41    9    98
27    Locked    42    3    19
28    Locked    42    7    74
29    Locked    42    4    23
30    Locked    42    4    30
31    Locked    42    14    110
3.1 Downstream channels
Channel    Channel Width (MHz)    FFT Type    Number of Active Subcarriers    Modulation (Active Profile)    First Active Subcarrier (Hz)
33    94    4K    1840    QAM 4096    1108
Channel ID    Locked Status    RxMER Data (dB)    PLC Power (dBmV)    Corrected errors (Active Profile)    Uncorrectable errors (Active Profile)
3.0 Upstream channels
Channel    Frequency (Hz)    Power (dBmV)    Symbol Rate (ksps)    Modulation    Channel ID
0    49600000    41.5    5120    QAM 16    1
1    43100000    41.3    5120    QAM 16    2
2    36600000    40.8    5120    QAM 16    3
3    30100000    40.5    5120    QAM 16    4
4    23600000    40    5120    QAM 16    5
Channel    Channel Type    T1 Timeouts    T2 Timeouts    T3 Timeouts    T4 Timeouts
0    ATDMA    0    0    1    0
1    ATDMA    0    0    0    0
2    ATDMA    0    0    0    0
3    ATDMA    0    0    0    0
4    ATDMA    0    0    0    0
3.1 Upstream channels
Channel    Channel Width (MHz)    Power (dBmV)    FFT Type    Modulation
6    10.4    36.7    2K    QAM 256
Channel    Channel Type    Number of Active Subcarriers    First Active Subcarrier (Hz)    T3 Timeouts    T4 Timeouts
6    OFDMA    208    74000000    0    0
Time    Priority    Description
05-11-2025 08:03:33    notice    GUI Login Status - Login Success from LAN interface
05-11-2025 07:59:54    notice    REGISTRATION COMPLETE - Waiting for Operational status
05-11-2025 07:59:43    notice    DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=cc:00:f1:a3:83:7e;CMTS-MAC=00:01:5c:a0:50:56;CM-QOS=1.1;CM-VER=3.1;
05-11-2025 07:59:41    warning    DHCP WARNING - Non-critical field invalid in response ;CM-MAC=cc:00:f1:a3:83:7e;CMTS-MAC=00:01:5c:a0:50:56;CM-QOS=1.1;CM-VER=3.1;
05-11-2025 07:59:38    notice    Honoring MDD; IP provisioning mode = IPv4
05-11-2025 07:59:36    critical    No Ranging Response received - T3 time-out;CM-MAC=cc:00:f1:a3:83:7e;CMTS-MAC=00:01:5c:a0:50:56;CM-QOS=1.1;CM-VER=3.1;
05-11-2025 07:59:34    critical    SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=cc:00:f1:a3:83:7e;CMTS-MAC=00:01:5c:a0:50:56;CM-QOS=1.1;CM-VER=3.1;
05-11-2025 07:59:32    critical    Cable Modem Reboot because of - Reboot UI
05-11-2025 07:42:15    critical    Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=cc:00:f1:a3:83:7e;CMTS-MAC=00:01:5c:a0:50:56;CM-QOS=1.1;CM-VER=3.1;
05-11-2025 07:42:15    critical    16 consecutive T3 timeouts while trying to range on upstream channel 2;CM-MAC=cc:00:f1:a3:83:7e;CMTS-MAC=00:01:5c:a0:50:56;CM-QOS=1.1;CM-VER=3.1;
05-11-2025 07:40:38    critical    Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=cc:00:f1:a3:83:7e;CMTS-MAC=00:01:5c:a0:50:56;CM-QOS=1.1;CM-VER=3.1;
05-11-2025 07:40:35    critical    Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=cc:00:f1:a3:83:7e;CMTS-MAC=00:01:5c:a0:50:56;CM-QOS=1.1;CM-VER=3.1;
05-11-2025 07:40:33    critical    16 consecutive T3 timeouts while trying to range on upstream channel 3;CM-MAC=cc:00:f1:a3:83:7e;CMTS-MAC=00:01:5c:a0:50:56;CM-QOS=1.1;CM-VER=3.1;
05-11-2025 07:40:33    critical    Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=cc:00:f1:a3:83:7e;CMTS-MAC=00:01:5c:a0:50:56;CM-QOS=1.1;CM-VER=3.1;
05-11-2025 07:40:31    critical    Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=cc:00:f1:a3:83:7e;CMTS-MAC=00:01:5c:a0:50:56;CM-QOS=1.1;CM-VER=3.1;
05-11-2025 07:40:28    critical    Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=cc:00:f1:a3:83:7e;CMTS-MAC=00:01:5c:a0:50:56;CM-QOS=1.1;CM-VER=3.1;
05-11-2025 07:40:27    critical    Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=cc:00:f1:a3:83:7e;CMTS-MAC=00:01:5c:a0:50:56;CM-QOS=1.1;CM-VER=3.1;
05-11-2025 07:40:27    critical    16 consecutive T3 timeouts while trying to range on upstream channel 4;CM-MAC=cc:00:f1:a3:83:7e;CMTS-MAC=00:01:5c:a0:50:56;CM-QOS=1.1;CM-VER=3.1;
05-11-2025 07:40:21    critical    Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=cc:00:f1:a3:83:7e;CMTS-MAC=00:01:5c:a0:50:56;CM-QOS=1.1;CM-VER=3.1;
05-11-2025 06:53:33    critical    Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=cc:00:f1:a3:83:7e;CMTS-MAC=00:01:5c:a0:50:56;CM-QOS=1.1;CM-VER=3.1;
05-11-2025 06:53:33    critical    16 consecutive T3 timeouts while trying to range on upstream channel 4;CM-MAC=cc:00:f1:a3:83:7e;CMTS-MAC=00:01:5c:a0:50:56;CM-QOS=1.1;CM-VER=3.1;
05-11-2025 06:51:09    critical    Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=cc:00:f1:a3:83:7e;CMTS-MAC=00:01:5c:a0:50:56;CM-QOS=1.1;CM-VER=3.1;
05-11-2025 06:51:06    critical    16 consecutive T3 timeouts while trying to range on upstream channel 3;CM-MAC=cc:00:f1:a3:83:7e;CMTS-MAC=00:01:5c:a0:50:56;CM-QOS=1.1;CM-VER=3.1;
05-11-2025 06:51:06    critical    Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=cc:00:f1:a3:83:7e;CMTS-MAC=00:01:5c:a0:50:56;CM-QOS=1.1;CM-VER=3.1;
05-11-2025 06:50:45    critical    Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=cc:00:f1:a3:83:7e;CMTS-MAC=00:01:5c:a0:50:56;CM-QOS=1.1;CM-VER=3.1;
05-11-2025 06:50:21    critical    16 consecutive T3 timeouts while trying to range on upstream channel 8;CM-MAC=cc:00:f1:a3:83:7e;CMTS-MAC=00:01:5c:a0:50:56;CM-QOS=1.1;CM-VER=3.1;
05-11-2025 06:50:21    critical    Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=cc:00:f1:a3:83:7e;CMTS-MAC=00:01:5c:a0:50:56;CM-QOS=1.1;CM-VER=3.1;
05-11-2025 06:50:17    critical    Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=cc:00:f1:a3:83:7e;CMTS-MAC=00:01:5c:a0:50:56;CM-QOS=1.1;CM-VER=3.1;
05-11-2025 06:50:16    critical    16 consecutive T3 timeouts while trying to range on upstream channel 0;CM-MAC=cc:00:f1:a3:83:7e;CMTS-MAC=00:01:5c:a0:50:56;CM-QOS=1.1;CM-VER=3.1;
05-11-2025 06:50:16    critical    Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=cc:00:f1:a3:83:7e;CMTS-MAC=00:01:5c:a0:50:56;CM-QOS=1.1;CM-VER=3.1;
05-11-2025 06:50:11    critical    Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=cc:00:f1:a3:83:7e;CMTS-MAC=00:01:5c:a0:50:56;CM-QOS=1.1;CM-VER=3.1;
05-11-2025 06:50:10    critical    Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=cc:00:f1:a3:83:7e;CMTS-MAC=00:01:5c:a0:50:56;CM-QOS=1.1;CM-VER=3.1;
05-11-2025 06:50:08    critical    Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=cc:00:f1:a3:83:7e;CMTS-MAC=00:01:5c:a0:50:56;CM-QOS=1.1;CM-VER=3.1;
33    Locked    0    4.3    15469913    0
  • Hey Blackfox, thank you for reaching out and we are so sorry to hear about your connection issues.
    We can see you've spoken to the team about this issue, did they manage to help at all?
        Are your 3.0 Upstream channels still all showing QAM 16 ?  These should all be QAM 64
        Also there should be zero or close to PostRS errors reported on the Hub.
        All these point to a bad connection or noise on the circuit.  One for VM to fix.
