xlncuk's avatar
xlncuk
hub3 ethernet ports max speed 100Mbps?
hi
had my 350Mbs service installed yesterday.
Having done some research and reading other posts on here it seems the ethernet ports wont go faster than 100Mbps (im currently getting about 85Mbps)
Yes the Wi-Fi is being reported at 350-375, but I'm really quite disappointed that it is not made obvious that I wont be able to get the max speed via ethernet, there doesn't seem to be much point being on the package I'm on if I cant take full advantage via Ethernet. I primarily use my connection for PC so gaming and Wi-Fi isn't really an option
Can anyone advise what my options are?
cheers
