rodders3601's avatar
rodders3601
Just joined
3 months ago
Hub won't reconnect after powering off
Having had slow connections and regular drop-offs, 2 weeks ago, I followed VM instructions to reboot my Hub 4 by powering it off, leaving for 30 secs, checking all connections, then powering back on. On power up it went through the usual boot cycle, but after multiple cycles, still wouldn't connect. This was in the morning. I left it powered on and it continued the boot cycle all through the day with no success. By the following morning, it had managed to reconnect itself and all was well. Then yesterday, I accidentally turned the power off to the hub and have subsequently been unable to get it to reconnect. It is stuck in a permanent loop of boot cycles. I have tried powering off and on a couple of times, but then just left it powered on overnight in the hope it would eventually reconnect as before, but no luck. It cycles between flashing white light, solid white light, flashing blue light, flashing white and blue light together, then no light. I have checked all connections, disconnected any non-essential LAN cables, but nothing seems to work. Can anyone offer any advice please?
  • I've reported it, but I've got to wait until Tuesday 2nd for an engineer to come out. That's why I was asking for advice
    • Alisha_C's avatar
      Alisha_C
      Hi rodderd3601,
      We are sorry you are having issues, if you go to the my VM app you can see if there is any different days you can pick. 👉https://virg.in/myvmapp
      We will also send you a PM, to see if we can look into this for you.
  • Tudor's avatar
    The primary place to report faults or for service requests is Customer Services on 0345 454 1111/150 if you have a VM landline or wait two or three days or longer at holiday times for a VM staff member to get to your post. This board is not a fault reporting system.
