CJ38's avatar
CJ38
Hub connection
Is there a maximum length for the broadband cable that connects the hub to the box where it enters the house
  • Simple answer no. Long answer is the total length of cable from the street box to hub has a limit, but I don’t know what it is. Unless you are a very long way from the street box the internal cable can be any length, but if it increases the technician may have to make adjustments at the street box to move you to another ‘tap’.
  • Tudor's avatar
  • jpeg1's avatar
    jpeg1
    There's not a fixed defined length, it will depend on other factors including how far the house is from the street cabinet.  Making it much longer will certainly need adjustments inside the street cabinet.
    If you ask VM to send a technician they can advise and do the changes for the fixed £25 charge. It is isn't something you can do yourself.
  • Anonymous's avatar
    Anonymous
    In Review
    …and if its fibre rather than coax, as long as you like.
    Even if it is coax another 10 to 20m may make little difference.
  • Thanks for reaching out to us on our Community Forums CJ38, and welcome back.
    I understand that since your post you have been able to speak to our team in relation to this matter.
    Do please come back to us if you want or need anything further assistance on this subject.
    All the best,
    David_Bn
