ScottMcl's avatar
ScottMcl
3 years ago
Hub 5x Modem Mode
I've just had Vm internet installed today and was given the 5x hub with fibre in home set up. I've got my own mesh routers ready to go but the hub settings don't have a "modem mode" like all videos and forums online say it should.
Any idea why I don't have this option ?
  • jbrennand's avatar
    Try a pinhole  reset firat as below.  That should restore any missing functionalirty
    Do a Hub “pinhole reset” - first make sure the 2 passwords on the Hub sticker are still there and legible first ! With the Hub still "switched on" throughout, press the reset pin in firmly with paper clip/SIM tray tool or similar "thin thing" and hold it firmly for at least 60 (a timed sixty) seconds, release the pin, leave for 5’ to stabilise - dont manually switch it off at any time. Passwords and SSID’s will reset to those on the sticker so log in and change them back to what they were/should be.
    Log in and option for modem mode will be there
    • Tudor's avatar
      Very few people know of the existence of the Hub5x, but a full pin hole reset is all you can try. Unless perhaps a firmware update restores this functionality.
