Mnm2397
3 years agoTuning in
Hub 5x modem mode workaround?
So I've been talking to virgin and I'm in the process of having a tech come out as my 1gig BB has been terrible meanwhile I've been wanting to get in to modem mode on the Hub 5x and while you can get to it via http://192.168.0.1/?page=modemmode it doesn't work, once you do this the ports are dead.
I have since been advised that as a workaround I can disable DHCP and WiFi and this will work the same as modem mode is this correct?
