John2021's avatar
John2021
Dialled in
1 month ago
Hub 5
Hi , I have a hub 3 and although virgin say my connections are all ok , I would disagree with them , I have a pod on my landing which has made connection upstairs better , but we find that connecting at the back of the house is hit and miss and going out onto the patio is more or less a waste of time trying to connect .
So , I am not after more speed which a hub on its own will not give , but better connections which I understand the hub 5 will give , does anybody have any info on things please .
  • jled's avatar
    jled
    Just browsing
    Hi, I had terrible WiFi till today. I tried till blue in the face to get my hub 3 replaced with better one, eventually just managed a replacement. This is equally as bad. Had one replaced about 11 months and it has gradually got worse. They tried to sell me faster data. Looked up online the hub is outdated and can't handle more than a few devices. The extra speed would have done nothing. I brought a netgear nighthawk rs100 for £89 from John Lewis. I put hub 3 in modem mode and then use rs100 for wifi and plugged ethernet. What a difference.
      This is more common than you may think as a solution to Wifi problems.
      Good, that's the way to go.  Yes, it's not for everyone, but it is a good solution and you are now in control of your own Wifi kit.
  • Who at Virgin are saying your WiFi is OK. Are you using the connect app to try and order another pod assuming you can still do it that way. If you are using the app and it's not giving you the results required to order another pod I believe other people have maybe walked down the garden to where they get a low enough reading to order one. 🙄
  • How can I get a hub 5 , virgin don’t seem to want to hand them out and if you say you need one they send you around in circles .
    • zhen7's avatar
      zhen7
      Dialled in
      Usually for higher tier services like M500 or Gig1/Gig2.
      What package are you on?
      I’ve bought 4x EERO MAX 7 recently because the SH5 isn’t any better at WiFi for me and my property but 4 of the newer WiFi 7 routers should help as almost everything in our house has WiFi 7 capability.
        The Hub 3 is suitable for M500 and getting 1 Gig is no guarantee of a Hub 5, it might a Hub 4.
  • Interesting replies , but I would prefer being given a hub 5 to see if any good first .
  • legacy1's avatar
    Yes VM say your connection is fine due to the way they test which is is Docsis fine and to the hub from there end they simply don't test what clients have to put up with are side and then they do the pods thinking it would solve it!
    so look to get your own wifi router with 1Gb or 2.5Gb ports and put hub in modem mode.
    If the WiFi is poor at the rear of the house, can you not just get another Pod?  I would have my doubts about the range of the Hub 5 being much better than the Hub 3.  Also note the Hub 5 is ax protocol and some older IoT have problems with this.
    • John2021's avatar
      John2021
      Dialled in
      Apparently the hub 5 has a better range from the research I have been able to do .
      • peter90's avatar
        peter90
        I think it's understandable for you to want to move away from hub3. hub4 and hub5 have better wifi tech. If I were in your situation I'd be wanting what you want. hub3 WiFi is out of date and very poor performance compared to default offerings from rival ISPs. All this pod/extender mucking about is papering over the problem.
        You're right to expect VM to resolve the root cause (Sky spend a lot of money on TV adverts showing off that their hubs have good WiFi coverage, it's not rocket science that the general public expect it).
        VM themselves have publicly acknowledged the problem (bad WiFi coverage) by saying they know they want to get everyone to hub5. It's just a shame they're not confident enough to give a timetable.
    • John2021's avatar
      John2021
      Dialled in
      I tried to get a pod , but as said , virgin recon everything is ok , so no .
