Nednats's avatar
Nednats
Up to speed
6 months ago
Hub 5 stuck on DOCSIS 3.0 – Ranging Failures, High Upstream Power, DOCSIS 3.1 Not Engaging
I’m having ongoing issues with my Virgin Media Gig1 connection. Although I’m using a Hub 5, the modem consistently fails to register on DOCSIS 3.1 and falls back to DOCSIS 3.0 after rebooting. This is accompanied by performance instability, occasional packet loss, and errors in the modem logs.
I’ve already:
  • Had the Hub reprovisioned by VM support,
  • Performed full pinhole resets and reboots,
  • Eliminated internal factors (tested with a single device on Ethernet, no VLANs or custom networking),
  • Checked that all coaxial cabling and splitters are secure.
Despite this, the issue persists — and support continues to send boilerplate instructions or suggest a Hub swap, neither of which addresses the real cause.
Symptoms:
  • Upstream transmit power: consistently at ~52 dBmV
  • DOCSIS 3.1 channels: detected but not fully locking
  • Repeated modem log entries including:
    • RNG-RSP CCAP Commanded Power in Excess of 6 dB Below DRW
    • T3/T4 ranging timeouts
    • No Unicast Maintenance opportunities received
    • DHCP WARNING – Non-critical field invalid in response
I’ve also monitored performance using ThinkBroadband BQM and observed clear packet loss and latency spikes aligning with the modem errors.
Request:
Please can this be reviewed and, if appropriate, escalated to your network or provisioning team? I am happy to accept a technician visit if the purpose is to check the external line or cabinet, but I want to avoid unnecessary in-home diagnostics, which have already been completed.
