Nednats's avatar
Nednats
Up to speed
8 months ago
Hub 5 stuck on DOCSIS 3.0 – Ranging Failures, High Upstream Power, DOCSIS 3.1 Not Engaging
I’m having ongoing issues with my Virgin Media Gig1 connection. Although I’m using a Hub 5, the modem consistently fails to register on DOCSIS 3.1 and falls back to DOCSIS 3.0 after rebooting. This is accompanied by performance instability, occasional packet loss, and errors in the modem logs.
I’ve already:
  • Had the Hub reprovisioned by VM support,
  • Performed full pinhole resets and reboots,
  • Eliminated internal factors (tested with a single device on Ethernet, no VLANs or custom networking),
  • Checked that all coaxial cabling and splitters are secure.
Despite this, the issue persists — and support continues to send boilerplate instructions or suggest a Hub swap, neither of which addresses the real cause.
Symptoms:
  • Upstream transmit power: consistently at ~52 dBmV
  • DOCSIS 3.1 channels: detected but not fully locking
  • Repeated modem log entries including:
    • RNG-RSP CCAP Commanded Power in Excess of 6 dB Below DRW
    • T3/T4 ranging timeouts
    • No Unicast Maintenance opportunities received
    • DHCP WARNING – Non-critical field invalid in response
I’ve also monitored performance using ThinkBroadband BQM and observed clear packet loss and latency spikes aligning with the modem errors.
Request:
Please can this be reviewed and, if appropriate, escalated to your network or provisioning team? I am happy to accept a technician visit if the purpose is to check the external line or cabinet, but I want to avoid unnecessary in-home diagnostics, which have already been completed.
  • I wanted to share some monitoring data following a series of upstream issues on 2 November 2025, between 18:45 and 18:50. During this time, my connection dropped repeatedly, and my Hub 5 logs recorded multiple T2/T3 timeouts, “No Maintenance Broadcasts for Ranging” messages, and a TCS Partial Service event.
    The connection re-established itself after a few minutes, but the ThinkBroadband BQM shows clear packet loss and latency spikes during that same window. My logs also recorded a sharp dip in upstream power across all channels, which then gradually recovered.
    Example log entries:
    18:45:56 – 16 consecutive T3 timeouts on upstream channels 0–4
    18:46:31 – No Maintenance Broadcasts (T2 timeout)
    18:49:58 – TCS Partial Service
    18:50:11 – CM-STATUS Event Type 5 (channels 18–36)
    Everything points to a short-lived upstream noise or node-level issue, rather than anything inside my property. The line has been stable since, but these recurring bursts match what I’ve been observing for several months.
    How do I get this investigated by the Network team?
    • Vikki_M's avatar
      Vikki_M
      Hi Nednats,
      Thanks for your post and welcome back to our community.
      We're sorry to hear you're still having some service issues.
      Do you have a complaint raised currently for these concerns?
      Please pop back to us when you can.
  • An engineer visited on 26/11/2025, where an equaliser was fitted to address marginal downstream levels,
    However, monitoring from 25–26 December shows renewed upstream instability, including:
    • Elevated upstream transmit power
    • Increased pre-RS errors
    • Timing irregularities (stat fetch jitter)
    There was no corresponding in-home activity at the time, and downstream metrics remained clean.
    As of 28 December, the BQM now shows:
    • Nednats's avatar
      Nednats
      Up to speed
      29 December, the BQM now shows:
      A lot of packet loss
