Nednats's avatar
Nednats
Dialled in
2 months ago
Hub 5 stuck on DOCSIS 3.0 – Ranging Failures, High Upstream Power, DOCSIS 3.1 Not Engaging
I’m having ongoing issues with my Virgin Media Gig1 connection. Although I’m using a Hub 5, the modem consistently fails to register on DOCSIS 3.1 and falls back to DOCSIS 3.0 after rebooting. This is accompanied by performance instability, occasional packet loss, and errors in the modem logs.
I’ve already:
  • Had the Hub reprovisioned by VM support,
  • Performed full pinhole resets and reboots,
  • Eliminated internal factors (tested with a single device on Ethernet, no VLANs or custom networking),
  • Checked that all coaxial cabling and splitters are secure.
Despite this, the issue persists — and support continues to send boilerplate instructions or suggest a Hub swap, neither of which addresses the real cause.
Symptoms:
  • Upstream transmit power: consistently at ~52 dBmV
  • DOCSIS 3.1 channels: detected but not fully locking
  • Repeated modem log entries including:
    • RNG-RSP CCAP Commanded Power in Excess of 6 dB Below DRW
    • T3/T4 ranging timeouts
    • No Unicast Maintenance opportunities received
    • DHCP WARNING – Non-critical field invalid in response
I’ve also monitored performance using ThinkBroadband BQM and observed clear packet loss and latency spikes aligning with the modem errors.
Request:
Please can this be reviewed and, if appropriate, escalated to your network or provisioning team? I am happy to accept a technician visit if the purpose is to check the external line or cabinet, but I want to avoid unnecessary in-home diagnostics, which have already been completed.
  • Here’s the latest BQM from yesterday. No reboots or dropouts, but latency remains consistently high with regular spikes and some minor packet loss.  The connection is more stable overall, but still not where it should be. Interested if anyone else sees similar patterns or has had luck getting this addressed by VM.
    • Daniel_Et's avatar
      Daniel_Et
      Hi Nednats 👋 Thank you for your posts and welcome to the Virgin Media Community 🙂
      We're sorry to hear about the issues you've been having 😔 How have things been since you posted?
      Advice on how to fix internet problems can be found here
      Regards,
      Daniel
      • Nednats's avatar
        Nednats
        Dialled in
        Thanks for the response, but I’ve already gone through the full set of basic troubleshooting steps, including wired-only testing, pinhole resets, reboots, and equipment verification.
        The issue here is not with Wi-Fi, nor is it a matter of internal cabling — I’ve documented upstream power readings exceeding 52 dBmV, repeated T3/T4 errors, and DOCSIS 3.1 upstream failures with fallback to 3.0.
        Please escalate this to the network or field team, as the evidence points to a cabinet or provisioning-level fault. I would appreciate a response that engages with the technical detail rather than repeating Tier 1-level advice
  • Just a quick follow-up in case anyone missed this — I’m still experiencing the same issues (high upstream power, T3/T4 errors, no DOCSIS 3.1 lock), and Virgin have yet to offer a resolution beyond the standard hub swap and internal wiring checks.
    If anyone has further insight or has had similar problems that were ultimately resolved (especially where a cabinet or CMTS issue was the root cause), I’d really appreciate hearing about your experience.
    Thanks again to everyone who’s contributed so far — your suggestions have been incredibly helpful.
    • Nednats's avatar
      Nednats
      Dialled in
      Sure — here’s a representative sample from the modem logs on July 11, which I included in my complaint to VM. These aren’t isolated entries — this type of error pattern repeats frequently:
      14:24:55 – RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value
      14:24:36 – No Ranging Response received - T3 time-out
      14:24:26 – No Maintenance Broadcasts for Ranging opportunities received - T2 time-out
      14:24:06 – Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
      These are all upstream provisioning or signal faults — not typical user-side problems. They also correlate with performance drops.
      For further context, here’s my ThinkBroadband BQM graph for the same date — you can clearly see the packet loss and jitter spikes that align with the logs:
      Sorry for just posting log extracts — I didn’t want to overload the post with pages of logs.
      • IPFreely's avatar
        IPFreely
        Rising star
        T2s have to be downstream, and T4 are almost always downstream issues.
        If an upstream channel drops because of upstream issues the log will reflect that many consecutive T3 timeouts happened ending in a T4.
        The OFDMA channel is more unstable because it's at higher modulation and as the issue is likely near you the error rate across the whole channel isn't high enough to justify lowering modulation profile.
    We lack sight of the contents of the Hub's Downstream and Upstream status tabs.
    Can the text from these be copy / pasted into the thread ?
    • Nednats's avatar
      Nednats
      Dialled in
      DOCSIS Status Summary:
      • DOCSIS mode: 3.1 (configuration tab shows DOCSIS 3.1)
      • Cable modem status: Online – DOCSIS 3.0
      • Downstream channels: 31 DOCSIS 3.0 channels locked (QAM256, SNR 40–41 dB)
      • Upstream channels: 5 DOCSIS 3.0 (QAM64, Power 51.5–52.3 dBmV), 1 DOCSIS 3.1 (OFDMA at 47.5 dBmV)
      DOCSIS 3.1 Channel Info:
      • Downstream 3.1 Channel 37: Locked, 94 MHz width, QAM4096, RxMER 39 dB
      • Upstream 3.1 Channel 10: 10.4 MHz width, QAM256, FFT 2K, OFDMA, 208 subcarriers
      Example Logs:
      • RNG-RSP power errors: “Commanded Power in Excess of 6 dB Below DRW”
      • Repeated: T3/T4 timeouts, DHCP warnings, No Maintenance Broadcasts
      3.0 Downstream channels
      DOCSIS 3.0 Downstream Channels
      Ch
      Frequency (MHz)
      Power (dBmV)
      SNR (dB)
      Pre RS Errors
      Post RS Errors
      1
      162
      3.8
      41
      269
      1
      2
      138
      4.0
      41
      747
      18
      3
      146
      4.1
      41
      467
      2
      4
      154
      4.1
      41
      259
      0
      5
      170
      2.8
      40
      374
      29
      6
      178
      4.0
      41
      145
      0
      7
      186
      4.2
      41
      148
      0
      8
      194
      4.4
      41
      54
      0
      9
      202
      4.4
      41
      152
      0
      10
      210
      4.6
      41
      159
      0
      11
      218
      4.6
      41
      162
      0
      12
      226
      4.5
      41
      25
      0
      13
      234
      4.6
      41
      180
      1
      14
      242
      4.3
      41
      294
      10
      15
      250
      4.1
      41
      196
      102
      16
      258
      4.0
      41
      97
      7
      17
      266
      4.1
      41
      6
      0
      18
      274
      4.2
      41
      0
      0
      19
      322
      4.0
      41
      3
      0
      20
      330
      3.6
      41
      12
      0
      21
      338
      3.8
      40
      74
      0
      22
      346
      3.8
      41
      45
      0
      23
      354
      3.8
      41
      8
      0
      24
      362
      3.8
      41
      6
      0
      25
      370
      3.6
      41
      19
      0
      26
      378
      3.4
      41
      10
      0
      27
      386
      3.2
      40
      9
      0
      28
      394
      3.1
      40
      6
      0
      29
      402
      3.3
      40
      15
      0
      30
      410
      3.3
      40
      22
      0
      31
      418
      3.2
      40
      20
      0
      DOCSIS 3.1 Downstream (OFDM)
      Channel
      Width (MHz)
      RxMER (dB)
      PLC Power (dBmV)
      Modulation
      Corrected Errors
      Uncorrectable Errors
      37
      94
      39
      0.8
      QAM 4096
      1,101,784,885
      2
      DOCSIS 3.0 Upstream Channels
      Ch
      Frequency (MHz)
      Power (dBmV)
      Modulation
      T1 Timeouts
      T2 Timeouts
      T3 Timeouts
      T4 Timeouts
      0
      49.6
      52.3
      QAM 64
      0
      0
      0
      0
      1
      43.1
      52.0
      QAM 64
      0
      0
      0
      0
      2
      36.6
      51.8
      QAM 64
      0
      0
      0
      0
      3
      30.1
      51.8
      QAM 64
      0
      0
      0
      0
      4
      23.6
      51.5
      QAM 64
      0
      0
      0
      DOCSIS 3.1 Upstream (OFDMA)
      Channel
      Width (MHz)
      Power (dBmV)
      Modulation
      T3 Timeouts
      T4 Timeouts
      10
      10.4
      47.5
      QAM 256
      0
      0
  • Tudor's avatar
    With upstream power that high I can understand 3.1 not connecting. The cause of this can be 1) you are a long way from street cabinet, moving to another tap on the cabinet may fix, 2) bad coax, 3) on wrong tap, 4) failing amplifier in street cabinet. All these require a technicians visit.
    • Nednats's avatar
      Nednats
      Dialled in
      While I agree that upstream power at 52 dBmV could point to physical issues, such as tap alignment or a failing amplifier in the cabinet, it's equally possible that this is a provisioning or CMTS configuration issue further upstream.
      Given that DOCSIS 3.1 channels are present but not being utilised, and the Hub consistently falls back to DOCSIS 3.0 even after reprovisioning, it suggests a potential misconfiguration involving the upstream OFDMA profile, signal windows, or modem registration.
      I'm happy to accept a technician visit, but the focus must be on signal alignment and CMTS-side provisioning, not simply replacing hardware or checking internal connections again.
      Throughout this process, Virgin Media support has repeatedly blamed internal issues including unsupported claims that my local network setup was to blame, or that the Hub should be replaced, despite clear diagnostics pointing to a line or network-level fault. These repeated misdirections have delayed proper investigation.
      I have now requested that this be escalated beyond Tier 1 and treated as a potential cabinet-side or provisioning issue, not an in-home or equipment fault.
      • gitty's avatar
        gitty
        It is not "falling back" to 3.0, because your primary channel is not 3.1. The one has nothing to do with the other.
    Have you checked on line and on the phone to see if there is a known fault in your street ?
    • Nednats's avatar
      Nednats
      Dialled in
      Yes. I have even had support run a line check and been told nothing is wrong. I explained the error logs but get ignored. 52 dBmV upstream is out of spec.
  • legacy1's avatar
    So how do you know your not on Docsis 3.1? because I'm confused too
    In Status it shows I'm in type docsis 3.0 but can see docsis 3.1 channels listed then in Configuration for Docsis mode is shows 3.1
    • Nednats's avatar
      Nednats
      Dialled in
      That’s a great question and honestly, it’s a bit confusing by design.
      Just because your Hub shows DOCSIS 3.1 channels available or “locked” in the status page doesn’t necessarily mean your connection is actively using DOCSIS 3.1.
      Here’s a quick breakdown:
      • DOCSIS 3.1 channels can appear listed or even "locked", but your modem may still be operating in DOCSIS 3.0 mode if there's an issue with signal quality, provisioning, or upstream compatibility.
      • In the status page, the “Cable Modem Status” or “Primary Downstream Channel” line will often say "DOCSIS 3.0" even when 3.1 is present that’s because it’s falling back to using 3.0 for actual data transport.
      • You can sometimes tell from the logs errors like RNG-RSP, T3 timeouts, or No Unicast Maintenance opportunities suggest that DOCSIS 3.1 tried to engage but failed.
      • The Configuration tab will often show “DOCSIS Mode: 3.1” regardless — that just means the modem supports DOCSIS 3.1, not that it’s currently using it.
      The only definitive way to know if your line is actively running in DOCSIS 3.1 is:
      1. If the modem status shows “DOCSIS 3.1” as the operational mode after startup, and
      2. If you're using an OFDM (3.1) downstream and OFDMA (3.1) upstream profile, without it reverting.
      In my case, it keeps reverting to 3.0 due to upstream power levels and ranging errors.
      Hope that helps clarify!
      • IPFreely's avatar
        IPFreely
        Rising star
        The primary channel will always show 3.0. Those are the only ones that can be primary channels.
        The configuration shows 3.1 because that's what your modem has been provisioned to lock to. A 3.1 modem can be provisioned with 3.0 channels and configuration only in which case there's a 3.0 configuration.
        If provisioned for 3.1, which all VM tiers are, and locked to channels what decides if you use them is how load balancing works on that hardware vendor. It's smart to fill 3.1 first if possible.
        Don't believe both upstream and downstream need to be OFDMA/OFDM, modems showed 3.1 prior to rollout of OFDMA.
        Obviously given the software on VM's kit, the 3.1 upstream isn't correctly reported to this day, best to hedge bets.
