danncus
1 year agoTuning in
Hub 5 no Ethernet after power outage
Hi. After a temporary power cut when the power has been restored the wifi is working, but non of the devices connected to the Ethernet are working. My tv box doesn’t even acknowledge the Ethernet cable is connected
help!
Try a pin-hole reset of the hub. If that fails you will have to contact customer services as a fault.
