adstang's avatar
adstang
Hub 5 keeps dropping out
Hello
I had the hub 5 installed 5 days ago ( upgrade from the hub 3 ) since then I have been having multiple drop outs where the Internet will go off and then come back on. Lights flash white on the modem and then back to solid white. We did not have this issue with the hub 3.
This is quite frustrating as we have security devices using wifi. And they need to be connected back everytime this happens.
I've tried restarting the modem etc.
Thank you
    Check for signal or error issues in the Upstream / Downstream status tabs of the Hub 5.
    • adstang's avatar
      adstang
      Hi thanks for your reply.
      I have taken a screenshot of the upstream / downstream as I'm not sure how to interpret it.
      Also in logs I have multiple instances of cable modem reboot because of - unknown.
       Thank you
      Adam
      • John_GS's avatar
        John_GS
        Hi adstang
        Sorry to hear of the issues with the broadband. I can see you've contacted the team since posting and booked a engineer visit in.
        Please let us know how the visit goes :).
