CrystalGipsy
1 year agoOn our wavelength
HUB 5 Dropping connection regualrly BR3 Area
I keep getting disconnects with my HUB5. I use it in modem mode and my router tells me its lost internet. Also lots of bandwidth drops whilst streaming video. Looking in the logs at these points I see lots of warnings at times when I get messages from my router that its lost interent. All is fine with it seeing the hub so this is definitely the connection. It also gives same issues when in standard router mode. This has been happening for quite some time now, but getting worse over the last week or so. Here is log from last day you can see lots of these warning.
12-07-2024 09:23:40 notice US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
12-07-2024 09:23:40 warning DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
12-07-2024 09:13:35 notice US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
12-07-2024 09:13:35 warning DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
12-07-2024 01:40:00 notice US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
12-07-2024 01:40:00 warning DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
12-07-2024 00:59:43 notice US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
12-07-2024 00:59:43 warning DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
12-07-2024 00:29:25 notice US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
12-07-2024 00:29:25 warning DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
12-07-2024 00:09:14 notice US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
12-07-2024 00:09:14 warning DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
11-07-2024 23:49:08 warning DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
11-07-2024 23:49:08 notice US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
11-07-2024 23:39:01 notice US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
11-07-2024 23:39:01 warning DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
11-07-2024 22:48:39 notice US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
11-07-2024 22:48:39 warning DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
11-07-2024 21:39:10 notice US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
11-07-2024 21:39:10 warning DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
11-07-2024 20:37:28 warning DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
11-07-2024 20:37:28 notice US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
11-07-2024 20:27:27 notice US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
11-07-2024 20:27:27 warning DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
11-07-2024 12:23:01 notice US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
11-07-2024 12:23:01 warning DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
11-07-2024 11:19:53 warning DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
11-07-2024 11:19:53 notice US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
11-07-2024 03:49:03 notice US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
11-07-2024 03:49:03 warning DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
11-07-2024 03:38:54 notice US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
11-07-2024 03:38:54 warning DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
04-07-2024 20:57:02 notice GUI Login Status - Login Fail from LAN interface3.0 Downstream channels
1 234000000 6.7 41 QAM 256 13
2 138000000 8.1 41 QAM 256 1
3 146000000 7.7 41 QAM 256 2
4 154000000 7.7 41 QAM 256 3
5 162000000 7.5 41 QAM 256 4
6 170000000 7.5 41 QAM 256 5
7 178000000 7.5 41 QAM 256 6
8 186000000 7.4 41 QAM 256 7
9 194000000 7.5 41 QAM 256 8
10 202000000 7 41 QAM 256 9
11 210000000 7.3 41 QAM 256 10
12 218000000 7.2 41 QAM 256 11
13 226000000 7.3 41 QAM 256 12
14 242000000 6.2 41 QAM 256 14
15 250000000 6.1 41 QAM 256 15
16 258000000 6.2 41 QAM 256 16
17 266000000 6.5 41 QAM 256 17
18 274000000 6.3 41 QAM 256 18
19 282000000 6.3 41 QAM 256 19
20 290000000 6.1 41 QAM 256 20
21 298000000 5.9 41 QAM 256 21
22 306000000 5.9 41 QAM 256 22
23 314000000 6.1 41 QAM 256 23
24 322000000 6.1 41 QAM 256 24
25 330000000 5.2 41 QAM 256 25
26 338000000 5.1 41 QAM 256 26
27 346000000 5.2 41 QAM 256 27
28 354000000 5.7 41 QAM 256 28
29 362000000 5.7 41 QAM 256 29
30 370000000 5.3 41 QAM 256 30
31 378000000 5.1 41 QAM 256 31
32 386000000 4.5 41 QAM 256 32
1 Locked 41 1581 21
2 Locked 41 2048 139
3 Locked 41 2145 76
4 Locked 41 2162 98
5 Locked 41 2164 67
6 Locked 41 2458 788
7 Locked 41 2678 670
8 Locked 41 2530 657
9 Locked 41 2504 670
10 Locked 41 1462 19
11 Locked 41 1466 0
12 Locked 41 1478 19
13 Locked 41 1567 20
14 Locked 41 1715 10
15 Locked 41 1661 0
16 Locked 41 1617 35
17 Locked 41 1616 13
18 Locked 41 1619 11
19 Locked 41 1723 16
20 Locked 41 1671 10
21 Locked 41 1713 6
22 Locked 41 1837 0
23 Locked 41 1903 23
24 Locked 41 2054 33
25 Locked 41 2081 85
26 Locked 41 2267 123
27 Locked 41 2328 126
28 Locked 41 2327 133
29 Locked 41 2356 177
30 Locked 41 2334 245
31 Locked 41 2375 103
32 Locked 41 2353 100
3.1 Downstream channels
159 92 4K 1800 QAM 4096 1128
159 Locked 42 4.4 1232974289 1162
3.0 Upstream channels
0 49600000 43.3 5120 QAM 64 1
1 43100000 42.8 5120 QAM 64 2
2 36600000 42 5120 QAM 64 3
3 30100000 41.8 5120 QAM 64 4
4 23600000 40.8 5120 QAM 64 5
0 ATDMA 0 0 0 0
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 21 0
3.1 Upstream channels
6 10 38.0 2K QAM 256
6 OFDMA 200 74000000 72 0
