- Client62Alessandro Volta
For 2.4GHz only use channels 1 or 6 or 11 at 20Mhz
For 5GHz try channels 36 or 44 at a bandwidth that suits your devices. - Steve1077On our wavelength
This is what I'm using
What is the problem ?
- newapolloVery Insightful Person
Hi Jbarr87
I haven't changed the settings on my hub 5 so they are set automatically by VM (screenshot below)
If you do want to make any changes then you need to open a browser and log into your hub 192.168.0.1 (or 192.168.100.1 if in modem mode) using the SSID and wifi settings password printed on a sticker on your hub
Advanced Settings > Wireless > Wireless Signal > click on Disable Channel Optimization at the bottom then click on Apply Changes.
Then beneath both the 5Ghz and 2.4GHz sections click on the manual button, and in the drop down box click on the channel number you want to change it to, then scroll down and click on Apply Changes.
(You could perform a search for an app such as wifi analyzer which tells you the strength of the channel you are connected on, and also shows other channels so you can decide if you want to change the channel number on your hub)
- jpeg1Alessandro Volta
Just remember that although you can apply manual settings, the router has its own built in fixed limits to suit regulatory requirements. You can't override them.
- Jbarr87Tuning in
Thanks for the help
- docgeorge89Tuning in
Hi all, I have a problem. After changing channels it's saving it for 5 minutes and after it's coming back to channel 44 for 5ghz and 11 for 2.4ghz. Virgin customer service sent me another router but it's doing the same thing. Anyone have any fix for this bug om hub 3.0 because virgin media it's not listening or even helping....
Do you have the Connect app installed on any devices ?
Yes I do, it should not be ?
- TudorVery Insightful Person
Yet another reason why a lot of users run in modem mode with their own routers.
I am actually thinking to do that, because I've been struggling with the vm wifi for over 6 months now
The Connect app ( even when closed ) will constantly try to force the VM Hub back into Smart Wi-Fi & Auto Channels. It has to be Uninstalled from all devices to prevent intrusion.
That actually worked. Can't believe that virgin media customer service or engineers they didn't know about this. Thank you very much! I really appreciate!
- Carley_SForum Team (Retired)
Hi docgeorge89
Sorry to hear you were having issues with customising your WiFi settings.
Glad to see that our Community members have been able to help in resolving this for you. Please let us know if you are having any further issues or have any questions at all. We'll be here to help on the Community Forums if needed.
Related Content
- 6 months ago
- 2 years ago
- 2 years ago
- 2 months ago
