PMac1's avatar
PMac1
Hub 5 best practice
Any best practice / lessons learnt for hub 5 which can be passed forward? Thanks. Just got mine today (replaced hub 3 which i am sending back).
  • legacy1's avatar
    If it don't work out for you theirs aways modem mode
    Disable "Smart Security" in the VM Connect app
    • PMac1's avatar
      PMac1
      I do not have it turned on but neither did i know about it nor bothered to look so it forced me to explore it. Thanks!
  • Tudor's avatar
    No better advice than to always run in modem mode, gets over nearly all the quirks/problems with the Hub5.
    • PMac1's avatar
      PMac1
      We live in interesting times and as such if it’s not fit for purpose as described as a quality router with its service charges to match then I’ll be deferring to Martin Lewis lol
      WiFi improvement has been observed so I’m content.
    If a Hub 5 is issued to us we will have a 3rd Party Router here ready to meet and greet it.
    We are not interested in dealing a Sagemcom's software quality issues where is takes months to years to fix some defects only to introduce more new defects.  Configuration management and testing staff need not apply.
